I’m suddenly getting many messages overflowing my openLuup logs. Device 43 is a door lock through Z-way. During this time nothing is being logged in the Z-way log and everything appears to be running normally. Yet every 2 seconds I see the messages below. How to debug? The logs are rolling fast enough that I haven’t been able to catch if there is something that starts it. I’ll try to restart and debug further. Hints?
2018-03-11 12:52:39.519 luup.variable_set:5: 43.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
2018-03-11 12:52:39.520 luup.variable_set:5: 43.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:0
2018-03-11 12:52:40.030 openLuup.server:: request completed (6313 bytes, 1 chunks, 2123 ms) tcp{client}: 0x16e0050
2018-03-11 12:52:40.566 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=726410221&Timeout=60&MinimumDelay=1500&_=1520789817138 HTTP/1.1 tcp{client}: 0x16e0050
2018-03-11 12:52:41.665 luup.variable_set:5: 43.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 0 now: 1 #hooks:0
2018-03-11 12:52:41.666 luup.variable_set:5: 43.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped was: 1 now: 0 #hooks:0
2018-03-11 12:52:42.194 openLuup.server:: request completed (6313 bytes, 1 chunks, 1627 ms) tcp{client}: 0x16e0050
2018-03-11 12:52:42.392 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=726410223&Timeout=60&MinimumDelay=1500&_=1520789817139 HTTP/1.1 tcp{client}: 0x16e0050
