Just checking if the recent VA update now allows to have the body of the alert sent in the notification itself instead of the generic notification (“note: Vera Alert from:xxxx”), and then having to open Pushbullet to see the details (“Bob opened the front door”).
If so, what is the syntax to be included in the configuration?
Thanks. It says I’m on 6.39 (not 6.37).
I changed the msg prefix to be this and let’s see how it goes. My goal is to just have time stamp and the msg in the notification itself without need to launch pushbullet. Fingers crossed!
Thanks. This works great when I push a normal message using pushbullet, but if I push a picture the pop-up notification on my iphone shows the filename of the jpg image and not the title I chose.
thanks - would be great if you could. I would use pushover instead, as it seems a better, faster and more robust service - but (unless I’m missing something) it doesn’t at present support sending jpegs…
