Morning
I setup Vera alerts and used test message and worked fine
I went to create scene / advanced / select Vera alerts / send alert
Typed message and have tried my email address / leaving blank / username
No success
Thank you in advance
Rich
Do you have an SMTP profile setup ?
Please send me the output of your Report command … you can hide the SMTP password.
[quote=“RichardTSchaefer”]Do you have an SMTP profile setup ?
Please send me the output of your Report command … you can hide the SMTP password.[/quote]
Hi
I have attached screenshot but changed password to xxxx and start of email to my email.
In the Vera Alerts, Send Alert Tab … You can test things out.
Make the following test messages, leaving the Recipients text entry blank.
- Send one message with your user name checked.
- Send one message with your profile checked.
If your profile and settings are setup properly you should get both test messages.
Now, Do not check any users or profiles.
Then the two type-in fields are just like the advanced tab of a Scene.
For the recipient you have the following options
- Leave it blank … This will use the profile specified for Default recipients in the the Settings Tab
- Type in a Vera User Name, This will use the profile specified for the Specified User in the Settings Tab
- Type in a Profile Name, This will use the specified profile
- Type in an Email address, This will clone an exising SMTP profile, with a new Email address. This will count as one of the profiles for licensing.
Hi
I done test with Vera username and with profile and got email…
I have attached screenshots from the scene as I still can’t get it working.
I have managed to get it working when select for ANY light off in scene and put my username with message. I can’t seem to get it to work with light on
Problem solved. I never had a trigger setup in the scene and not having this didn’t send Vera alert message. Working good now
