Now, I have discovered where sqblaster stores the captured codes, If you do a backup to your box.net account you can have access to the codes for each device…
How in vera is little bit complicated manager IR devices, I am sendig in pronto code format the IR codes of my sqblaster and works fine and very fast !
Now I need create a scene sending many codes to run a job…Like turn tv ON and put in determined Channel…
I would like to send this codes in LUUP window…
someone with example of this sending …would be good a code to give a pause between each sending of codes…
thanks for help …
