Hi, here there’s a way to send text messages from Vera to Telegram.
[ol][li]Download and install Telegram from your store[/li]
[li]Open the app and search BotFather bot, start a chat with it and type /newbot[/li]
[li]Follow the instructions and create a bot choosing name and username, BotFather will answer you with a token, keep it.[/li]
[li]Now search the bot you just created typing its username[/li]
[li]Start a chat typing some text message[/li]
[li]Visit “https://api.telegram.org/bot/getUpdates” where is your token[/li]
[li]The webpage will give you a messagge like this: “{“ok”:true,“result”:[{“update_id”:501403863,
“message”:{“message_id”:3,“from”:{“id”:166545828,“first_name”? ? ?”, keep the chat_id (this is an example)[/li]
[li]Create a scene in your Vera and in “Also, execute the following Luup code” enter the following LUA code:
[/li][/ol]
Thank you for posting this. I’ve been looking at ways to have my vera send me notifications via iMessage command line, but ran into the problem that the applescript interface doesn’t allow me to send messages to myself (though I do it all the time when getting stuff off my iphone).
In looking at the API, it looks like it’s also capable of doing quite a bit via the API. I’m primarily interested in sending photos on events. It looks like it’ll take a little bit of lua backend work to do the encoding of a photo/video, but it could be worth it.
Is there a possibility to use a variable as input.[/quote]
Yes, use … to concatenate.local myText = "<this is my text>"
luup.inet.wget('https://api.telegram.org/bot<token>/sendMessage?chat_id=<chat_id>&text=' .. myText,5);
Hi, very soon the instructions to integrate CallMeBot with Vera will be available.
CallMeBot will allow you to make Telegram Phone Calls (not text messages) from Vera’s scenes.
It has been announced today on their Twitter: https://twitter.com/CallMeBot_com
The bot will ring your phone and say the message that you want.
Very nice and free.
