Hi guys,
Im sure this may have been asked before, but is there a way to send an alert if a sensor hasnt contacted/updated Vera for a defined period.
Eg: i have a temp sensor which should report the temp at least every 5mins. Vera stores the epoch time of the “LastUpdate”
so i guess some rule needs to be created to do the math and fire alert if needed.
As id be wanting to do this for several (all?) sensors im thinking it would need to be a pretty generic script/function…so would you do this in Startup LUA or PLEG??
Cheers,
Greg
