I’d like to have my motion sensor (Fibaro) to act as a trigger for a bell. The bell is connected to the Fibaro power plug. I only want to send a pulse so it rings shortly.
I am new to z-wave so if anyone can help me I’d be very glad!
Create a scene to turn the ring (device) on and in that same scene turn is of “after 2 or 3” seconds.
You cannot send a pulse, you can only do on then off as per the previous post. The problem you will get get will be that z-wave delays will mean that the bell will probably ring longer than you want.
Give it a go. It can’t hurt to try.
