Ugh… using 899, trying to access the smartphone interface. Was working fine yesterday under 899…
I went to plugins, made sure the smartphone interface was installed…
But just to make sure, I uninstalled it then hit “save” then rebooted… i then continued to reinstall it, hit save again, and reboot again. Just to make sure the plugin was installed FOR SURE.
I cleared the cache, cookies, and history on the safari iphone browser and continued to the URL ra1.findvera.com/mobile.php
I logged in and hit the “graphical version” button AND…
STILL “selected plugin is not installed…” like i said it was working fine yesterday, idk
I am also having a problem with “Selected Plugin is Not Installed” when I try to access remotely with my iPhone. Have replacement dongle (2.78) and upgraded firmware to 1.0.918. I can’t figure out how to install the smartphone plugin. When I go to devices in Vera and select Luup plugins and then select install/uninstall plugins I get a “dead end” - white box with nothing in it. No selections to make, no instructions, etc. I tried going to Luup files and downloading “L_sPhoneUI.lua” and then uploading that file and nothing happens. I am totally confused!
Can someone point me in the right direction to learn how to install these plugins or is there a bug in the system?
Went to Vera early this morning and selected Install/Unistall Plugins and, for the 1st time in thirty or so attempts, there was actually a screen with plugins to select. So I selected the smarthphone item and “installed it”. A few minutes later I was able to use my iPhone to remotely access Vera! I was ready to go out and buy a lottery ticket.
Went back to Vera 30 minutes later and the screen where I found plugins earlier was once again blank. Have tried several more times and screen is still blank.
I guess the old saying “timing is everything” must be true. The good news is my iPhone access is still working (I have my fingers crossed).
I’m getting this, too. Using 10.899 with an iPhone. Tried the above URL’s/uninstall/install/etc. No joy. Could it be somethng in the iPhone software that auto-upgraded?
