How do you work out why a reload happened? Just curious
C
C
first I get notifications on my phone whenever I get a luup reload. It is something I did with my startup lua.
2 things to track: I usually look at the logs but they sometimes get wiped out and I see every thing which happened after the reload but nothing just before. In this case, I have setup grafana with historian and noticed that my HEM stopped reporting any update at the very same time the reload occured. I have been noticing it go a little quirky lately creating a 3rd “ghost” phase occasionaly by sending some strange data to the vera.
The problem is also for vera to handle this a little better… poping a message instead of reloading luup which helps nothing would have been much better.
Thanks. I did wonder if it was possible with the inbuilt functionality. Seems not really. Agreed. Failing catastrophically without any reporting is pretty poor.
C
Hey @rafale77
Are the VeraMods files in posts 165 / 166 up to date? I’m just waiting on a USB SSD drive to arrive and am going to try this on a Vera Secure in the next day or so - should it work OK on a Secure?
Similarly, is the extroot.sh in your other thread up to date and should that work OK on a Secure too?
Also, how does this mod and the extroot mod impact on future firmware updates? Should they just apply over the top and not mess up any of these changes?
And finally for backup / restore, should that work OK too?
My intention is to “prepare” some Secure using your mods and extroot scripts and then restore backups from my live Vera (a mixture of Edge, Plus & Secure) - do you foresee any issues with that?
Your best guess is fine, I have access to several units for testing so I’m not too worried about bricking them … I can also provide any info you may need beforehand for the Secure (partition layouts, versions, etc).
Hi Martyn:
The latest version of the script is in post 175-176. It is the 3 file version.
The order by which you should apply the script is:
I have tested them quite extensively on my spare unit having run and bricked the vera quite a few times and recovered as many times. I believe it should work on the secure as well given it is basically the same unit. with a dual core CPU and more memory. Just to be sure though, I would appreciate if you could post the banner you see as you login (I want to check what version of openWRT it is running) and the output of “dmesg” and “df -h” right after a boot so I can map the flash drive.
Not critical but just in case.
Ah yeah post 175-176 that’s what I mean, I was just too lazy to go back and check when I wrote the post
Here’s the output:
[code]BusyBox v1.19.4 (2017-01-30 10:11:42 UTC) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
|_____|| |||||___||| |____|
|| W I R E L E S S F R E E D O M
BARRIER BREAKER (Bleeding Edge, r39638)
*** MiOS LTD. ( www.mios.com ) ***
*** WARNING : ***
*** Any changes made to the system without ***
*** guidance from MiOS support will VOID ***
*** your future Support requests ***
---------------------------------------------------[/code]
[ 5.136000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 5.136000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 5.136000] cdc_xr_usb_serial 1-2.2:1.0: This device cannot do calls on its own. It is not a modem.
[ 5.152000] cdc_xr_usb_serial 1-2.2:1.0: ttyXR_USB_SERIAL0: USB XR_USB_SERIAL device
[ 5.180000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 5.196000] Freeing unused kernel memory: 228K (82447000 - 82480000)
[ 5.252000] usb 1-2.3: new full-speed USB device number 5 using xhci-hcd
[ 5.304000] usb 1-2.3: New USB device found, idVendor=04e2, idProduct=1420
[ 5.320000] usb 1-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.336000] usb 1-2.3: Product: Exar USB UART
[ 5.344000] usb 1-2.3: Manufacturer: Exar Corp.
[ 5.352000] usb 1-2.3: SerialNumber: D162257002
[ 5.376000] add_ep parameters, dev_speed 2, is_in 1, isTT 1, ep_type 3, maxp 64, interval 64, burst 0, mult 0, ep 0x9beea300, ep_ctx 0xa1c24240, sch_ep 0x9bf01a80
[ 5.408000] check tt_intr_bw interval 8, frame_idx 0
[ 5.420000] check tt_intr_bw interval 8, frame_idx 1
[ 5.428000] check OK............
[ 5.436000] [DBG] BPKTS: 1, BCSCOUNT: 3, BBM: 1
[ 5.436000] [DBG] BOFFSET: 8, BREPEAT: 0
[ 5.436000] add_ep parameters, dev_speed 2, is_in 0, isTT 1, ep_type 2, maxp 64, interval 1, burst 0, mult 0, ep 0x9beea280, ep_ctx 0xa1c24120, sch_ep 0x9bf01800
[ 5.464000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 5.464000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 5.464000] add_ep parameters, dev_speed 2, is_in 1, isTT 1, ep_type 2, maxp 64, interval 1, burst 0, mult 0, ep 0x9beea2ac, ep_ctx 0xa1c24140, sch_ep 0x9bf01580
[ 5.496000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 5.496000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 5.496000] cdc_xr_usb_serial 1-2.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 5.516000] cdc_xr_usb_serial 1-2.3:1.0: ttyXR_USB_SERIAL1: USB XR_USB_SERIAL device
[ 6.808000] Button Hotplug driver version 0.4.1
[ 6.844000] JFS: nTxBlock = 4019, nTxLock = 32158
[ 6.868000] SCSI subsystem initialized
[ 6.880000] usbcore: registered new interface driver usb-storage
[ 7.468000] 78:FFFFFF94:FFFFFFB4:FFFFFFF7:FFFFFF85:53
[ 7.476000] Raeth v3.1 (Tasklet)
[ 7.488000] phy_free_head is 0x1c3a000!!!
[ 7.496000] phy_free_tail_phy is 0x1c3bff0!!!
[ 7.504000] txd_pool=a1c40000 phy_txd_pool=01C40000
[ 7.516000] ei_local->skb_free start address is 0x9be526dc.
[ 7.528000] free_txd: 01c40010, ei_local->cpu_ptr: 01C40000
[ 7.540000] POOL HEAD_PTR | DMA_PTR | CPU_PTR
[ 7.548000] ----------------+---------+--------
[ 7.560000] 0xa1c40000 0x01C40000 0x01C40000
[ 7.568000]
[ 7.568000] phy_qrx_ring = 0x01c39000, qrx_ring = 0xa1c39000
[ 7.584000]
[ 7.584000] phy_rx_ring0 = 0x01c3c000, rx_ring0 = 0xa1c3c000
[ 7.624000] MT7530 Reset Completed!!
[ 7.632000] change HW-TRAP to 0x17ccf
[ 7.640000] set LAN/WAN LLLLW
[ 7.652000] GMAC1_MAC_ADRH -- : 0x00007894
[ 7.660000] GMAC1_MAC_ADRL -- : 0xb4f78553
[ 7.676000] CDMA_CSG_CFG = 81000000
[ 7.680000] GDMA1_FWD_CFG = 20710000
[ 10.196000] ESW: Link Status Changed - Port4 Link UP
[ 11.144000] jffs2: notice: (380) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 48 of xref (0 dead, 37 orphan) found.
[ 11.644000] ra2880stop()...Done
[ 11.656000] Free TX/RX Ring Memory!
[ 12.600000]
[ 12.600000] set gpio 30 input
[ 12.616000]
[ 12.616000] set gpio 33 input
[ 12.628000]
[ 12.628000] set gpio 23 output
[ 12.636000]
[ 12.636000] set gpio 22 output
[ 12.644000]
[ 12.644000] set gpio 23 to 0
[ 12.652000]
[ 12.652000] set gpio 22 to 0
[ 20.628000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 20.664000] loop: module loaded
[ 20.676000] gre: GRE over IPv4 demultiplexor driver
[ 20.688000] ip_gre: GRE over IPv4 tunneling driver
[ 20.716000] u32 classifier
[ 20.720000] input device check on
[ 20.728000] Actions configured
[ 20.736000] Mirror/redirect action on
[ 20.748000] usbcore: registered new interface driver btusb
[ 20.764000] usbcore: registered new interface driver ark3116
[ 20.776000] usbserial: USB Serial support registered for ark3116
[ 20.796000] usbcore: registered new interface driver cdc_acm
[ 20.804000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 20.824000] usbcore: registered new interface driver cdc_wdm
[ 20.836000] usbcore: registered new interface driver ch341
[ 20.852000] usbserial: USB Serial support registered for ch341-uart
[ 20.868000] usbcore: registered new interface driver cp210x
[ 20.880000] usbserial: USB Serial support registered for cp210x
[ 20.896000] usbcore: registered new interface driver ftdi_sio
[ 20.912000] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 20.932000] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 20.948000] usbcore: registered new interface driver pegasus
[ 20.964000] Error: Driver 'pl2303' is already registered, aborting...
[ 21.108000] Ralink APSoC Hardware Watchdog Timer
[ 21.124000] usbcore: registered new interface driver sierra
[ 21.136000] usbserial: USB Serial support registered for Sierra USB modem
[ 21.180000] xt_time: kernel timezone is -0000
[ 21.188000] usbcore: registered new interface driver asix
[ 21.204000] usbcore: registered new interface driver ax88179_178a
[ 21.220000] usbcore: registered new interface driver cdc_eem
[ 21.232000] usbcore: registered new interface driver cdc_ether
[ 21.244000] usbcore: registered new interface driver cdc_ncm
[ 21.260000] usbcore: registered new interface driver cdc_subset
[ 21.272000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 21.284000] Type=Restricted Cone
[ 21.304000] nf_conntrack version 0.5.0 (8039 buckets, 32156 max)
[ 21.328000] usbcore: registered new interface driver option
[ 21.340000] usbserial: USB Serial support registered for GSM modem (1-port)
[ 21.360000] Error: Driver 'pl2303' is already registered, aborting...
[ 21.388000] PPP generic driver version 2.4.2
[ 21.400000] PPP MPPE Compression module registered
[ 21.412000] NET: Registered protocol family 24
[ 21.420000] usbcore: registered new interface driver qmi_wwan
[ 21.436000] usbcore: registered new interface driver sierra_net
[ 21.448000] usbcore: registered new interface driver smsc95xx
[ 21.468000] usbcore: registered new interface driver cdc_mbim
[ 21.484000] Error: Driver 'pl2303' is already registered, aborting...
[ 21.524000] Error: Driver 'pl2303' is already registered, aborting...
[ 24.208000] jffs2: notice: (1882) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 37.320000] 78:FFFFFF94:FFFFFFB4:FFFFFFF7:FFFFFF85:53
[ 37.332000] Raeth v3.1 (Tasklet)
[ 37.344000] phy_free_head is 0x1c3a000!!!
[ 37.352000] phy_free_tail_phy is 0x1c3bff0!!!
[ 37.360000] txd_pool=a1c40000 phy_txd_pool=01C40000
[ 37.372000] ei_local->skb_free start address is 0x9be526dc.
[ 37.380000] free_txd: 01c40010, ei_local->cpu_ptr: 01C40000
[ 37.392000] POOL HEAD_PTR | DMA_PTR | CPU_PTR
[ 37.404000] ----------------+---------+--------
[ 37.412000] 0xa1c40000 0x01C40000 0x01C40000
[ 37.420000]
[ 37.420000] phy_qrx_ring = 0x01c39000, qrx_ring = 0xa1c39000
[ 37.436000]
[ 37.436000] phy_rx_ring0 = 0x01c3c000, rx_ring0 = 0xa1c3c000
[ 37.480000] MT7530 Reset Completed!!
[ 37.488000] change HW-TRAP to 0x17ccf
[ 37.496000] set LAN/WAN LLLLW
[ 37.508000] GMAC1_MAC_ADRH -- : 0x00007894
[ 37.516000] GMAC1_MAC_ADRL -- : 0xb4f78553
[ 37.524000] CDMA_CSG_CFG = 81000000
[ 37.528000] GDMA1_FWD_CFG = 20710000
[ 37.548000] device eth0.2 entered promiscuous mode
[ 37.556000] device eth0 entered promiscuous mode
[ 37.588000] br-wan: port 1(eth0.2) entered forwarding state
[ 37.600000] br-wan: port 1(eth0.2) entered forwarding state
[ 39.604000] br-wan: port 1(eth0.2) entered forwarding state
[ 40.064000] ESW: Link Status Changed - Port4 Link UP
[ 44.056000]
[ 44.056000] set gpio 23 to 0
[ 44.068000]
[ 44.068000] set gpio 23 to 1
[ 44.820000] usb 1-2.4: new high-speed USB device number 6 using xhci-hcd
[ 44.848000] usb 1-2.4: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 255, changing to 11
[ 44.868000] usb 1-2.4: New USB device found, idVendor=058b, idProduct=0041
[ 44.884000] usb 1-2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 44.900000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 3, maxp 512, interval 1024, burst 0, mult 0, ep 0x9afdf400, ep_ctx 0xa1c49080, sch_ep 0x9b6d1c80
[ 44.932000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 44.932000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 44.932000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9afdf380, ep_ctx 0xa1c49100, sch_ep 0x9b6d1a00
[ 44.964000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 44.964000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 44.964000] add_ep parameters, dev_speed 3, is_in 0, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9afdf3ac, ep_ctx 0xa1c490a0, sch_ep 0x9b6d1800
[ 44.996000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 44.996000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 44.996000] cdc_acm 1-2.4:1.0: This device cannot do calls on its own. It is not a modem.
[ 45.012000] cdc_acm 1-2.4:1.0: ttyACM0: USB ACM device
[ 46.412000] usb 1-2.4: USB disconnect, device number 6
[ 47.412000] usb 1-2.4: new high-speed USB device number 7 using xhci-hcd
[ 47.444000] usb 1-2.4: config 1 has too many interfaces: 6, using maximum allowed: 4
[ 47.464000] usb 1-2.4: New USB device found, idVendor=1bc7, idProduct=0026
[ 47.476000] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 47.496000] usb 1-2.4: Product: 6 CDC-ACM Data Only
[ 47.504000] usb 1-2.4: Manufacturer: Telit
[ 47.512000] usb 1-2.4: SerialNumber: 354678055800986
[ 47.524000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9b7b0580, ep_ctx 0xa1c48080, sch_ep 0x9b6d1c00
[ 47.556000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.556000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.556000] add_ep parameters, dev_speed 3, is_in 0, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9b7b05ac, ep_ctx 0xa1c48060, sch_ep 0x9b6d1900
[ 47.584000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.584000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.584000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9bd20500, ep_ctx 0xa1c480c0, sch_ep 0x9b6d1d00
[ 47.616000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.616000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.616000] add_ep parameters, dev_speed 3, is_in 0, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9bd2052c, ep_ctx 0xa1c480a0, sch_ep 0x9afdf100
[ 47.644000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.644000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.644000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9ac7cf00, ep_ctx 0xa1c48100, sch_ep 0x9b5dc700
[ 47.676000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.676000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.676000] add_ep parameters, dev_speed 3, is_in 0, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9ac7cf2c, ep_ctx 0xa1c480e0, sch_ep 0x9b6d1700
[ 47.708000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.708000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.708000] add_ep parameters, dev_speed 3, is_in 1, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9b581600, ep_ctx 0xa1c48140, sch_ep 0x9b5dce80
[ 47.740000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.740000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.740000] add_ep parameters, dev_speed 3, is_in 0, isTT 0, ep_type 2, maxp 512, interval 1, burst 0, mult 0, ep 0x9b58162c, ep_ctx 0xa1c48120, sch_ep 0x9b5dcc00
[ 47.768000] [DBG] BPKTS: 1, BCSCOUNT: 0, BBM: 1
[ 47.768000] [DBG] BOFFSET: 0, BREPEAT: 0
[ 47.804000] option 1-2.4:1.0: GSM modem (1-port) converter detected
[ 47.816000] usb 1-2.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 47.840000] option 1-2.4:1.1: GSM modem (1-port) converter detected
[ 47.856000] usb 1-2.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 47.876000] option 1-2.4:1.2: GSM modem (1-port) converter detected
[ 47.896000] usb 1-2.4: GSM modem (1-port) converter now attached to ttyUSB2
[ 47.912000] option 1-2.4:1.3: GSM modem (1-port) converter detected
[ 47.924000] usb 1-2.4: GSM modem (1-port) converter now attached to ttyUSB3
[ 49.672000] jffs2: notice: (3331) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 51.012000] Bluetooth: hci0 urb 9b4cf500 failed to resubmit (2)
[ 51.024000] Bluetooth: hci0 urb 9accbf00 failed to resubmit (2)
[ 57.824000]
[ 57.824000] led off GPIO_LED_ZIGBEE
[ 60.380000]
[ 60.380000] led off GPIO_LED_SERVICE
[ 60.660000]
[ 60.660000] led off GPIO_LED_LPRF
[ 61.428000]
[ 61.428000] led on GPIO_LED_ZIGBEE
[ 61.924000]
[ 61.924000] led on GPIO_LED_ZWAVE
[ 62.252000]
[ 62.252000] led on GPIO_LED_LPRF
[ 62.468000]
[ 62.468000] led on GPIO_LED_LPRF
[ 62.732000]
[ 62.732000] led on GPIO_LED_POWER
[ 62.792000]
[ 62.792000] led on GPIO_LED_ZWAVE
[ 63.120000]
[ 63.120000] led on GPIO_LED_ZIGBEE
[ 63.416000]
[ 63.416000] led on GPIO_LED_SERVICE
[ 63.680000]
[ 63.680000] led on GPIO_LED_3G
[ 64.120000]
[ 64.120000] led off GPIO_LED_ZIGBEE
[ 64.268000]
[ 64.268000] led off GPIO_LED_LPRF
[ 64.436000]
[ 64.436000] led off GPIO_LED_SERVICE
[ 64.564000]
[ 64.564000] led off GPIO_LED_3G
[ 65.620000]
[ 65.620000] led on GPIO_LED_BLUETOOTH
[ 67.744000]
[ 67.744000] led on GPIO_LED_WIFI
[ 67.864000]
[ 67.864000] led on GPIO_LED_BLUETOOTH
[ 71.992000]
[ 71.992000] led off GPIO_LED_ZIGBEE
[ 74.184000]
[ 74.184000] led off GPIO_LED_LPRF
[ 74.240000]
[ 74.240000] led off GPIO_LED_SERVICE
[ 74.628000]
[ 74.628000] led on GPIO_LED_ZIGBEE
[ 74.736000]
[ 74.736000] led on GPIO_LED_ZWAVE
[ 74.844000]
[ 74.844000] led on GPIO_LED_LPRF
[ 74.956000]
[ 74.956000] led on GPIO_LED_LPRF
[ 75.064000]
[ 75.064000] led on GPIO_LED_ZWAVE
[ 75.164000]
[ 75.164000] led on GPIO_LED_ZIGBEE
[ 75.276000]
[ 75.276000] led on GPIO_LED_SERVICE
[ 75.388000]
[ 75.388000] led on GPIO_LED_3G
Filesystem Size Used Available Use% Mounted on
rootfs 8.0M 4.5M 3.5M 56% /
/dev/root 10.5M 10.5M 0 100% /rom
tmpfs 251.2M 7.5M 243.7M 3% /tmp
/dev/mtdblock6 8.0M 4.5M 3.5M 56% /overlay
overlayfs:/overlay 8.0M 4.5M 3.5M 56% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock10 50.0M 11.5M 38.5M 23% /storage
/dev/mtdblock10 50.0M 11.5M 38.5M 23% /etc/cmh-firmware
/dev/mtdblock10 50.0M 11.5M 38.5M 23% /etc/cmh-backup
/dev/mtdblock9 10.0M 10.0M 0 100% /mios
Also added a ps output:
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 1.6 0.1 1436 672 ? S 16:46 0:04 /sbin/procd
root 2 0.0 0.0 0 0 ? S 16:46 0:00 [kthreadd]
root 3 0.2 0.0 0 0 ? S 16:46 0:00 [ksoftirqd/0]
root 4 0.0 0.0 0 0 ? S 16:46 0:00 [kworker/0:0]
root 5 0.0 0.0 0 0 ? S< 16:46 0:00 [kworker/0:0H]
root 6 0.0 0.0 0 0 ? S 16:46 0:00 [kworker/u4:0]
root 7 0.1 0.0 0 0 ? S 16:46 0:00 [migration/0]
root 8 0.0 0.0 0 0 ? S 16:46 0:00 [rcu_bh]
root 9 0.6 0.0 0 0 ? S 16:46 0:01 [rcu_sched]
root 10 1.3 0.0 0 0 ? S 16:46 0:03 [migration/1]
root 11 0.1 0.0 0 0 ? S 16:46 0:00 [ksoftirqd/1]
root 12 0.0 0.0 0 0 ? S 16:46 0:00 [kworker/1:0]
root 13 0.0 0.0 0 0 ? S< 16:46 0:00 [kworker/1:0H]
root 14 0.0 0.0 0 0 ? S< 16:46 0:00 [khelper]
root 15 0.0 0.0 0 0 ? S 16:46 0:00 [kworker/u4:1]
root 103 0.0 0.0 0 0 ? S< 16:46 0:00 [writeback]
root 105 0.0 0.0 0 0 ? S< 16:46 0:00 [bioset]
root 107 0.0 0.0 0 0 ? S< 16:46 0:00 [kblockd]
root 115 0.2 0.0 0 0 ? S 16:46 0:00 [khubd]
root 127 1.2 0.0 0 0 ? S 16:46 0:03 [kworker/1:1]
root 150 0.0 0.0 0 0 ? S 16:46 0:00 [kswapd0]
root 151 0.0 0.0 0 0 ? SN 16:46 0:00 [ksmd]
root 152 0.0 0.0 0 0 ? S 16:46 0:00 [fsnotify_mark]
root 153 0.0 0.0 0 0 ? S< 16:46 0:00 [crypto]
root 259 0.6 0.0 0 0 ? S 16:46 0:01 [kworker/0:1]
root 289 0.0 0.0 0 0 ? S< 16:46 0:00 [krfcommd]
root 293 0.0 0.0 0 0 ? S< 16:46 0:00 [deferwq]
root 305 0.0 0.0 0 0 ? S 16:46 0:00 [kworker/u4:2]
root 321 0.0 0.0 0 0 ? S 16:46 0:00 [jfsIO]
root 322 0.0 0.0 0 0 ? S 16:46 0:00 [jfsCommit]
root 323 0.0 0.0 0 0 ? S 16:46 0:00 [jfsCommit]
root 324 0.0 0.0 0 0 ? S 16:46 0:00 [jfsSync]
root 339 0.0 0.0 0 0 ? S< 16:46 0:00 [kworker/1:1H]
root 340 0.0 0.0 0 0 ? S< 16:46 0:00 [kworker/0:1H]
root 381 0.6 0.0 0 0 ? SN 16:47 0:01 [jffs2_gcd_mtd6]
root 501 0.1 0.0 892 92 ? S 16:47 0:00 /sbin/ubusd
root 502 0.0 0.0 768 80 ttyS1 Ss+ 16:47 0:00 /sbin/askfirst ttyS1 /bin/ash --login
root 1883 5.5 0.0 0 0 ? SN 16:47 0:13 [jffs2_gcd_mtd10]
root 2075 0.2 0.0 1048 356 ? S 16:47 0:00 /sbin/logd -S 16
root 2080 0.1 0.1 3672 624 ? S 16:47 0:00 /usr/bin/btn_g550 -c /etc/config/button_g550.ini -d
root 2083 0.0 0.0 0 0 ? S 16:47 0:00 [kworker/1:2]
root 2156 0.2 0.1 1584 756 ? S 16:47 0:00 /sbin/netifd
root 2360 0.0 0.0 1768 364 ? S 16:47 0:00 udhcpc -p /var/run/udhcpc-br-wan.pid -s /lib/netifd/dhcp.script -f -t 0 -i br-wan -C
root 2747 0.0 0.0 1772 376 ? S 16:47 0:00 /usr/sbin/crond -f -c /etc/crontabs -l 5
root 2781 0.0 0.2 4068 1160 ? S 16:47 0:00 /usr/sbin/lighttpd -f /etc/lighttpd/lighttpd.conf
root 2786 0.0 0.1 1736 588 ? Ss 16:47 0:00 /usr/sbin/dbus-daemon --system
root 2962 0.0 0.0 1104 300 ? Ss 16:47 0:00 /usr/sbin/ntpclient -c 6 -i 600 -s -l -D -p 123 -h 3.openwrt.pool.ntp.org
root 3395 0.0 0.0 0 0 ? S< 16:47 0:00 [kworker/u5:0]
root 3396 0.0 0.0 0 0 ? S< 16:47 0:00 [hci0]
root 3397 0.0 0.0 0 0 ? S< 16:47 0:00 [hci0]
root 3400 0.0 0.0 0 0 ? S< 16:47 0:00 [kworker/u5:1]
root 3401 0.0 0.0 0 0 ? S< 16:47 0:00 [kworker/u5:2]
root 3458 0.0 0.0 1768 364 ? S 16:47 0:00 /usr/sbin/ntpd -n -p 0.openwrt.pool.ntp.org 1.openwrt.pool.ntp.org 2.openwrt.pool.ntp.org 3.openwrt.pool.ntp.org
root 3490 0.0 0.1 1780 524 ? S 16:47 0:00 /bin/sh /usr/bin/Start_LuaUPnP.sh
root 3611 0.0 0.0 1768 432 ? S 16:47 0:00 /bin/sh /usr/bin/Start_serproxy.sh
root 3629 0.2 0.2 3364 1452 ? S 16:47 0:00 /usr/bin/bluetoothd -n -E
root 3653 0.0 0.0 0 0 ? S 16:47 0:00 [kworker/0:2]
root 3686 0.0 0.0 0 0 ? S 16:47 0:00 [kworker/1:3]
root 3886 0.0 0.1 1944 600 ? S 16:47 0:00 /bin/sh /usr/bin/cmh-ra-daemon.sh 127.0.0.1 80 vera-us-oem-relay41.mios.com 30656 SOME REDACTED STUFF
root 3927 0.2 0.0 1232 352 ? S 16:47 0:00 ssh -p 232 -T -y -i /etc/cmh-ra/keys/cmh-ra-key.priv -R 30656:127.0.0.1:80 cmh-ra@vera-us-oem-relay41.mios.com
root 3965 0.0 0.0 1772 464 ? S 16:47 0:00 /bin/sh /usr/bin/Start_NetworkMonitor.sh
root 3985 0.0 0.1 1780 520 ? S 16:47 0:00 /bin/sh /usr/bin/StreamingTunnelsManager.sh
root 4074 0.0 0.0 1792 500 ? S 16:47 0:00 /bin/sh /usr/bin/Start_WanFailover.sh
root 4102 0.3 0.7 8404 3796 ? Sl 16:47 0:00 /usr/bin/NetworkMonitor
nobody 4368 0.0 0.0 960 336 ? S 16:47 0:00 /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf -k
root 5213 5.0 2.0 75636 10640 ? Sl 16:47 0:10 /usr/bin/LuaUPnP
root 5456 0.0 0.0 1148 352 ? S 16:48 0:00 /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300
root 5750 0.0 0.0 1024 340 ? S 16:48 0:00 /usr/bin/serproxy 127.0.0.1 127.0.0.1 SOME REDACTED STUFF
root 7463 0.8 0.1 1212 536 ? Rs 16:49 0:01 /usr/sbin/dropbear -F -P /var/run/dropbear.1.pid -p 22 -K 300
root 7556 0.0 0.0 1772 508 pts/0 Ss 16:49 0:00 -ash
root 9337 0.0 0.0 1760 116 ? S 16:50 0:00 sleep 60
root 9368 0.0 0.0 1760 116 ? S 16:50 0:00 sleep 58
root 9822 0.1 0.1 1600 596 ? S 16:51 0:00 /usr/sbin/pppd nodetach ipparam 3g ifname 3g-3g lcp-echo-interval 5 lcp-echo-failure 3 +ipv6 nodefaultroute usepeerdns persist maxfail 1 connect USE_APN=m2m005229.attz DIALNUMBER=*99# /usr/sbin/chat -t5 -v -E -f /etc/chatscripts/3g.cha
root 9906 1.0 0.1 1952 676 ? S 16:51 0:00 /bin/sh /usr/bin/WanFailover_Watch.sh --3g-iface 3g-3g
root 9930 0.0 0.1 1952 564 ? S 16:51 0:00 /bin/sh /usr/bin/WanFailover_Watch.sh --3g-iface 3g-3g
root 9934 0.0 0.0 1764 368 ? S 16:51 0:00 ping -I br-wan -q -w 3 -c 1 98.139.183.24
root 9941 0.0 0.0 1296 336 pts/0 R+ 16:51 0:00 ps aux
Thank you! Very helpful.
I cracked up at the rootfs partition… 8MB!! come on mios… what were you thinking?
Vera Lite 11MB, Vera Edge 10MB, Vera Plus 8.6MB, Vera Secure 8MB… The more we upgrade the less storage we have.
Unfortunately the output of your dmesg is a bit tardy in the process (it starts after 5s) so I cannot map the drive but I think I have enough information.
It runs the exact same kernel as the Vera Plus so you can run all the scripts the exact same way. It is even more critical for you to start with extroot.
The ps output is also helpful. The secure seems to have a couple of extra scripts for 3G failover which obviously the VeraMod scripts will not disable.
Sounds good, SSD’s should be here tomorrow so will take a crack at it.
I’ve actually been running all my Vera “mostly” disconnected from Vera Cloud for the last three or four years using some simple scripts to kill off most Cloud connectivity aside from logs and alerts and a few other bits … I forget now, it was ages ago that I figured it all out, but I run all my Vera behind hardware firewalls so it’s easy to see what they are trying to connect to. The one benefit of my simple scripts is that you can run stop / start at will which is handy if you find you need to connect back up to the Cloud for something.
Your mods obviously go much further though!
So far so good with the extroot on the Secure
Unfortunately I think running VeraMods has killed it tho
After the reboot there’s only a few things running (no LuaUPnP process for example).
Here’s the log output from running VeraMods, seems quite a few errors there?
So, I think this was a permissions problem … if you follow the instructions and unzip the VeraMod* .zip files on a Windows PC then all the permissions obviously get removed.
If you then move those folders across to Vera and execute the modvera.sh file it copies various files from those folders into the Vera file system and those files are now no longer executable.
I fixed that by looking at each modvera.sh file and working out which files had been copied into the Vera file system and then changed the permissions to be correct (e.g. chmod 755 x.sh) to match the permissions on files from a standard Vera.
Unfortunately after a reboot it seems that it’s now a brick … not even SSH access …
I removed the SSD, rebooted from internal, added the SSD back and re-did the extroot to get back to default for now.
Let me know there’s anything I can provide to help to troubleshoot? Would a tar of the original root filesystem help?
Wow, Yes you are right, you need to change the permissions again if the files go through windows. Mac OS seems to be able to maintain the original permission information. Good thing you had it extrooted. It is the ultimate anti-brick failsafe.
If you could run the scripts and paste the output of the script while you are still in SSH mode, I will look into it. There might be some differences on the vera secure which may not allow all of the updates I made so I may have to take them down a notch.
Actually I managed to get a bit further along … the Secure seems to be pretty different to the Plus, for example the package source in the MiOS repo is mios_g550 and not mios_g450 - that was the big thing that seemed to cause the bricking before (understandably).
After I changed the opkg.conf and opkg2.conf in the VeraMods folders (along with rectifying the permissions issues) it seems happier now (in as much as LuaUPnP is up) although still some problems, for example the Secure has a default installed Plugin that handles the battery & siren aspects and this is cr*pping out at the moment and causing LUA startup errors.
Doing a diff between some of your Plus based modified .sh files and the originals on the Secure shows quite a few differences - I unfortunately don’t have a Plus on a current firmware versions to compare your mods against to see what you’ve changed or what is a genuine difference between the Plus & Secure models. I’ve guessed at a few (e.g. the set_led.sh is different on Secure because it has a lot more LEDs) and will fiddle about a bit more.
Oh, also “serialapi_controller_static_ZM5304_US.hex” - do you have the versions for EU / ANZ too?
Ohh Do not use the ZM5304 to upgrade your zwave firmware. The plus uses a slightly different version: The ZM5202 if I remember correctly you definitely want to keep the original. If your firmware had a ZM5304 file then it is very likely not being used by the luup engine. In case you really want it. I attached it.
It sounds like there is some extra work to be done as indeed some sh scripts are different on the vera secure. I have downloaded and mounted the verasecure firmware to take a peek. Most of the mods should be minor but since I do not have a vera secure I will have a hard time testing it.
Ah yes, the Secure is all ZM5202 files (EU, US, ANZ) - is there an updated version of that available? Also, I assume that upgrading it would have been a manual step and not carried out automagically? I guess not if the file names are different anyway?
I think I roughly figured out most of the changes now and it seems to be running OK. There was a stupid bug in the Plugin I mentioned before where it tries to get the value of any credit on the internal SIM card from the MiOS servers and fails (probably due to the tunnels being down). This results in a nil value concatenation error … schoolboy coding mistake really and easy to fix.
Happy to test a Secure version of your script if you get the chance to make one … no problem if not as I think I am OK as-is but a packaged version may work better for anybody else.
One other thing I spotted, I’ve not looked too closely but the BusyBox upgrade seemed to lose some commands, for example unzip, diff, whoami (you can see what was removed in the log I posted earlier).
I have come to believe that these are actually not even used by the vera so I don’t know why they are there. I have booted my vera without it. It should. Unfortunately the SDK from Silicon Image only has full firmware for the SD3502 (which is the USB stick) and the API file for the ZM5304 so I am not able to find the ZM5202 version of it.
[quote=“martynwendon, post:215, topic:199140”]Happy to test a Secure version of your script if you get the chance to make one … no problem if not as I think I am OK as-is but a packaged version may work better for anybody else.
One other thing I spotted, I’ve not looked too closely but the BusyBox upgrade seemed to lose some commands, for example unzip, diff, whoami (you can see what was removed in the log I posted earlier).[/quote]
Yes I know that the latest busybox version removes a few commands which I have for some of them had to get back through opkg as standalone binaries. The standalone binaries actually better and more complete than the busybox one which is really useful only if you are very limited in storage space. With extroot, no reason to sweat it. The new busybox however has increased the vera’s responsiveness which is why I prefer it.
I’ve had this running for several days now on a Secure and in the most part it appears OK.
This was based on me merging your Plus-based scripts / changes into the Secure which seems have been largely successful.
One thing that I am struggling with though is log-rotation, not sure why but the LuaUPnP log never rotates successfully - that is, it gets rotated to LuaUPnP.1 but a new LuaUPnP file isn’t created.
Also, the ntpclient logs rotation looks like:
294409 Feb 25 14:05 log.ntpclient.gz.gz
-rw-r--r-- 1 root root 292446 Feb 25 14:05 log.ntpclient.gz.gz.gz.gz
-rw-r--r-- 1 root root 293818 Feb 25 14:05 log.ntpclient.gz.gz.gz.gz.gz.gz
-rw-r--r-- 1 root root 292673 Feb 25 14:05 log.ntpclient.gz.gz.gz.gz.gz.gz.gz.gz
I think I’m using the Rotate_Logs.sh from your mods as-is, so I wondered if you have noticed the same issue?
It looks like the rotate logs need to be modified for the Vera Secure. It is likely that the name of the log is different. I will look into it when I have a few minutes today.
Actually I think I worked out what was happening.
If I ran Rotate_Logs.sh manually with force flag then it gets:
[code]root@:/etc/init.d# /usr/bin/Rotate_Logs.sh 1
ps: invalid option – a
BusyBox v1.29.3 () multi-call binary.
Usage: ps
Show list of processes
w Wide output
Starting Ntpclient
Usage: ps
w Wide output
ps: invalid option – f
Usage: ps
w Wide output
Usage: ps
w Wide output
Start rotating logs PID=31563, force rotate=1, free space=254464 KB, min=5120 KB, cmh logs size=8 KB, max=20480 KB, now=1551120901, last rotation=1551103502, diff=289 min 59 sec, max=12 hours
/usr/bin/Rotate_Logs.sh: line 129: stat: not found
sh: 358400: unknown operand
Usage: ps
w Wide output
Usage: ps
w Wide output
Usage: ps
w Wide output
Finished log rotation for serial=, version=1.7.4002, date=2019-02-25_18-55-03
ArchiveLogsOnServer is disabled, no logs uploaded[/code]
It seems that ps version from new busybox in /bin doesn’t support the a flag - or perhaps it doesn’t “pass through” to the full ps binary in /usr/bin/ - on an original Secure I can do /bin/ps aux OR /usr/bin/ps aux and get the same valid output.
In any case I can workaround the issue by hardcoding the path in the Rotate_Logs.sh script and if I do that I now get:
root@:/usr/bin# ./Rotate_Logs.sh 1
Start rotating logs PID=1569, force rotate=1, free space=255696 KB, min=5120 KB, cmh logs size=8 KB, max=20480 KB, now=1551121690, last rotation=1551120901, diff=13 min 9 sec, max=12 hours
./Rotate_Logs.sh: line 129: stat: not found
Finished log rotation for serial=, version=1.7.4002, date=2019-02-25_19-08-12
So it now barfs on the “stat” command - which is missing from the busybox install (compared to an original Secure).
I assume this all works OK on the Plus?
touche…
From memory I had to run
opkg install coreutils-stat
and
opkg install procps-ps
