Hello - I notice the setpoints on the thermostat are not always showing correctly. This may be a Vera thing but would it be possible to check? I am using TemperatureSetpoint1 to set the device.
I have no thermostat so hard to check but :
- what version of ALTUI ?
- can you remove the theme to be sure ?
- have you checked the option about UI7 behavior for thermostat ?
It is displaying correctly again. I will do as you advise and repost next time it happens.
