I’ve got a few Secure 321 or HRT4-ZW’s and they work great for what I want. I’ve never had a problem with it in homewave, but adding another one now, I cannot control the thermostat set point in homewave.
I add a device to a screen, and then there is no thermostat in the device list.
I can add a 3line control and get the details from the thermostat though, set points etc.
If this is a newly added device, try changing the setpoint on the thermostat and/or the Vera UI, then try adding it again in HomeWave. Vera sometimes does not report device properties for new devices until the device has reported a new value, and in this case HomeWave will not pick it up in the list.
The weird bit is that each time the set point isn’t displayed on the UI dashboard. I can change it with the +/- buttons and type, but it doesn’t stay displayed. The changes are sent to the thermostat. Could this have anything to do with it?
Thanks.
