On a door/window sensor I have a notification for User1, that successfully sends a Vera Alerts. I have a very similar notification just different wording for User2/Profile2 that does not work.
When I run the Vera Alerts report, the notification is present, but the user field is blank. It doesn’t matter which user I choose for this notification, the user field is always blank in Vera Alerts. If I select User1 and User2, User1 does show up in the user field on the report, but not User2.
Perhaps unsurprisingly, when the user field is blank and the notification is sent and it matches Vera Alerts, I get this in the log
LuaInterface::CallFunction_Job device 62 function SVeraAlert_VeraAlert1_DeviceNotification_jo
b failed [string "module("L_VeraAlert", package.seeall)..."]:1245: bad argument #1 to 'gmatch' (string expected, got nil)
The notification does appear under Account → My Alerts, when the sensor is tripped. Yes, I opened the Notification Configuration panel in Vera Alerts.
