Quick newbi question here. Why would someone want a secondary controller? Isn’t the zwave mesh communication enough? Or is this more like load balancing kinda thing? If so, after what point a secondary controller becomes necessary?
Read up on Vera bridging. It is used to increase Z-Wave coverage by adding a second(or more) Z-Wave network to cover an area that a single Z-Wave network might not reach. A common scenario for this is an outbuilding where the gap between buildings cannot be reached across by a single Z-Wave network.
Another reason is if your network exceeds the Z-Wave maximum device count of 232.
[quote=“Z-Waver, post:2, topic:185888”]Read up on Vera bridging. It is used to increase Z-Wave coverage by adding a second(or more) Z-Wave network to cover an area that a single Z-Wave network might not reach. A common scenario for this is an outbuilding where the gap between buildings cannot be reached across by a single Z-Wave network.
Another reason is if your network exceeds the Z-Wave maximum device count of 232.[/quote]
Hey Z, any clever way of getting an accurate device count, other than going one by one in the UI and making some assumptions about plugins, etc?
[quote=“tomgru, post:3, topic:185888”][quote=“Z-Waver, post:2, topic:185888”]Read up on Vera bridging. It is used to increase Z-Wave coverage by adding a second(or more) Z-Wave network to cover an area that a single Z-Wave network might not reach. A common scenario for this is an outbuilding where the gap between buildings cannot be reached across by a single Z-Wave network.
Hey Z, any clever way of getting an accurate device count, other than going one by one in the UI and making some assumptions about plugins, etc?[/quote]
Don’t get to caught up on device count. Every plugin uses a different amount of RAM. I can have very few devices but heavy RAM users and run into problems with a 1/4 of the max device count. And it’s very possible but most users don’t have 232 z-wave devices. It’s usually the plugins that are the killers.
Hey Z, any clever way of getting an accurate device count, other than going one by one in the UI and making some assumptions about plugins, etc?[/quote]You’ll count em, and you’ll like it! ;D
Or, you could run @RexBeckett’s little script to dump them all to a text file. Then use this Linux command to count the content of the file.
wc -l /www/devlist.txt
