Hi
I have successfully installed the SRT322 Thermostat & Receiver (SSR303) and everything works as it should so far having my Thermostat giving commands to the Receiver as well as Veraplus changing target temperature. The only problem I have is that the Receiver (SSR303) sends delayed (5-10 minutes) updates back to the controller so I cannot keep data of when Heat is ON or OFF. There are cases where the Heat_ON lasts only 2 minutes and in this case I will NOT receive any updates at all.
This happens when Thermostat decides to switch Heat or when I manually switch on-off the Receiver using the physical buttons without involving VeraPlus.
Thermostat is associated to Receiver using group-2 and tried also group-1 without success.
Thank you !
Edit **** changed problem description from no-updates to delayed-updates
