I have the T-Stat tied to a scene that would turn off everything whenever no one’s home.
When coming home, I added a scene to turn the T-Stat back on. However, the Honeywell thermostat setting only allows to trigger heat/cool. Not a big deal since I would only need to modify the scene twice a year as the season change but it’ll be nice to be able to set it on a seasonal basis or tied to Wunderground plugin so that if say the outside weather is <60 then trigger heat and if it’s >75 then trigger cool or even if say the inside of the house is at X temperature etc…
how can I achieve this?
