Does anyone make a z wave temperature probe for measuring water temperature or ambient temps.?
Ideally the temp sensor would be a 10k thermistor or a PT 1000 RTD. The sensor could be put into a sensor well for fluid measurement or placed in a location to measure ambient temps. The device would be powered by line voltage or have a very LONG life battery.
I have seen single devices like Evergreen but the temperature sensor is located on the circuit board and can not be separated easily and can not be placed outdoors.
[size=14pt]Update[/size]:
This is incredible that no one makes a simple temperature probe that can be used to measure a fluid by putting the problem in a thermal well!!!
Someone should develop this product or allow for a standard sensor to be wired to and existing product.
Applications:
Measure pool or spa temp.
Measure the temp of a circulation loop in a hotel - so you can turn off the circulator based on time or temp.
Measure the temp of a tank of fluid for kitchens or food service trays Synapse Wireless is developing something but using their own radios)
Walk in Freezer temp.
Brewerys
Winery
Waterbeds - do they still have those?
What the heck?
