Hi @stuart
Not sure if this has been requested before, so i might be alone in this ![]()
Would you consider adding the description of an event as another variable within your plugin ?
Hi @stuart
[quote=āparkerc, post:1, topic:193564ā]Hi @stuart
Would you consider adding the description of an event as another variable within your plugin ?[/quote]
I could easily add it to gc_jsonEvents and you can access it from there. How do you want to use it ?
Hi @Stuart
Iāve been working to integrate my Vera with Panicās Status Board app on iOS , and not being a programmer, I recently found a panel that I would like to try and tweak to reference variables held in your GCal app.
So if the description was to be added as its own variable, I would look to include it in a new panel(HTML widget) which I would try to generate and host on Vera.
** if there was scope to search the description for keywords too, that could come in handyā¦**
Ive attached an example.
I will make a change so that the description information is included in the gc_jasonEvents variable. That way - you can build your own scene and play with Lua code to get it to do whatever you want.
Iāll post an updated file in the next day or two.
Thanks so much @Stuart
One other thing - as Iām not a programmer/developer, would you know how I would remove the ā[{ā characters that will already be in the gc_JsonEvents variable field when you add the Description ?
The [{ is displayed in UI5 is because UI5 is not displaying what it should. The variable is an encoded json string but itās being truncated in the UI. There really is data there !
There is some sample lua code in the instructions for GCal3 that shows how to access the variable and get at the various entries. You will have to learn some Lua - but you likely needs to do so anyway so you can get the data into the application you plan on using to display it all.
I admire your optimism in me ![]()
Ok, I think is have found the code you are referring to.
function testJson() local GCAL_SID = "urn:srs-com:serviceId:GCalIII" local jsonEvents = luup.variable_get(GCAL_SID, "gc_jsonEvents",lul_device) if (jsonEvents == "[]") then -- equivalent of a nul so don't try return endlocal json = require(?json?)
local eventList =json.decode(jsonEvents)
package.loaded.json = nil
local numberEvents = #eventList
local startevent, startDate, startTime, endevent, endTime, eventname, event for i = 1,numberEvents do
startevent = eventList[i].eventStart
startDate = os.date(ā%Y-%m-%dā, startevent)
startTime = os.date(ā%H:%M:%Sā, startevent)
endevent = eventList[i].eventEnd
endTime = os.date(ā%H:%M:%Sā, endevent)
eventname = eventList[i].eventName
return
Hi @stuart
In preparation for the description being added, I thought I would have a go at using your sample code to decode the JSON,
That way I can hopefully try work out what I might need to lookup/learn to do to extract just the descriptionāpart in the futureā¦
[code]function testJson()
local GCAL_SID = āurn:srs-com:serviceId:GCalIIIā
local jsonEvents = luup.variable_get(GCAL_SID, āgc_jsonEventsā,lul_device)
if (jsonEvents == ā[]ā) then ā equivalent of a nul so donāt try
return
local json = require āakb-jsonā
startevent = eventList.eventStart
endevent = eventList.eventEnd
eventname = eventList.eventName
return
testJson()
[/code]
However, after addressing one error before, I am still getting the following errors in the log ???
01 09/02/16 8:04:39.989 GetLuaInterface can't find device type: 0/0x1b1f1d0 str: (null) <0x310ba680> 01 09/02/16 8:04:39.990 luup_variable_get interface 0x1ab65b8 args 3 <0x310ba680> 01 09/02/16 8:04:39.991 LuaInterface::StartEngine failed run: 0 [string "function testJson() ..."]:11: attempt to get length of local 'eventList' (a nil value) <0x310ba680> 01 09/02/16 8:04:39.991 JobHandler_LuaUPnP::RunLua failed: function testJson()
what version of vera are you using UI5 or UI7 ?
In UI5 it should be
local json = require "json"
and in UI7 it should be
local json = require "dkjson"
This is because vera did not provide a json encode/decode library in UI5 - so GCal downloads one (json) . In UI7 vera provided one (dkjson). Of course this may have been inconsistent on veraās side (across models), so GCal loads json if it cannot find dkjson.
Not sure where you got the idea to use akb-json. Perhaps from someone elseās example where they had loaded that version onto their machine.
Thanks @stuart
Replacing lul_device reference with the actual device ID allows the code to work without any errors. But now Iām stuck ![]()
Can you help me with what to do next just to see the contents of gc_JasonEvents variable e.g in the log?
What do I need to add at the end ?
What do you want to do with the variables once you have them ? Are you interested in all the events in gc_jasonEvents or just the currently triggered event ? Some other event ? How are you planning on executing your code ā as part of a scene ? If so what would be the scene trigger ?
Writing them to the log file will only tell you that you have them (which is not that interesting). Painting a scenario of what you want to do will let others have a better idea and offer advice.
Hi Stuart
My current goal is to create a (web) widget (using the same design I posted earlier/above) to work with the Status Board app to show what the next trigger event is.
To do that I was just going to try and work out some code that will capture the required information / variables and then generate the webpage which would be hosted on Vera in /www/
Using your code above, my question was because I was not sure how I could run the code and see the decoded results - just to see if it worked (or not).
Iām mocking it up at the moment and im thinking I can replace bits of the template each time using (is it called concatenation? ) " ⦠gc_variable ⦠" with the information I could get from your plugin.
All with no formal programming understanding/ experience ![]()
Hi Stuart
Here is my working current code, not the pretty version just yet.
What I canāt work out/need is how to create (extract) the other bits of event information I need such as the start time, the month, day and the description.
[code]local GCAL_SID = āurn:srs-com:serviceId:GCalIIIā
local gcNext = luup.variable_get(GCAL_SID, āgc_NextEventā, 330)
local gcNextTime = luup.variable_get(GCAL_SID, āgc_NextEventTimeā, 330)
local text = [[
<div id="GCal3 Container">
<h2>Next GCal Event</h2>
<ul class="custom-listing">
<div class="small_cal_month_dash">.. Three letter month to go here ..</div>
<div class="small_cal_day_dash">.. Two digit date to go here .. </div>
<div class="dash_time">.. Day .. " - " ..start time .. </div>
<p>
<p><strong><span class="caps">Vera Home Control</span></p>
.. Event description ..
</p>
</div><!-- GCal3 Container -->
</body>]]
local file = io.open(ā/www/gcalnext.htmlā, āwā)
file:write(text)
file:close()[/code]
@ parkerc
Update your V2.3 with the two files located here. This version includes the description in gc_jsonEvents
http://forum.micasaverde.com/index.php/topic,26692.msg292407.html#msg292407
The code below should get you going. Paste it into a scene and test it out.
luup.log("*********************** VERA EVENT EXECUTED ****************************")
local lul_device = 50 -- change this to be the Gcal plugin number
function getEventDescription(device, event, eventtime )
-- returns the description of the matching event, or
-- "No Events" if there are no matching events
-- "No Description" if there is no description
-- get the contents of gc_jsonEvents
local jsonEvents = luup.variable_get(GCAL_SID, "gc_jsonEvents",device)
return "No Events"
-- read the events in gc_jsonEvents into an array
local json = require("json") -- depending on your vera version you may need to use require("dkjson")
local eventstart, starttime, eventname, eventdescription
-- now process the array one entry at a time
for i = 1,#eventList do
-- get the start time for this event
eventstart = eventList[i].eventStart
-- create a string with the same start format as gc_nextEventTime
starttime = os.date("%H:%M %b %d", eventstart) .. " to " -- will be shorter then eventtime parameter
-- get the event name
-- truncate it because the variable gc_NextEvent is truncated for display reasons
eventname = string.sub(eventname,1,40) -- will be same size or shorter then event parameter
-- get the description if it has one otherwise use a default
eventdescription = eventList[i].eventDescription or "No Description"
-- test to see if the name and start time match
-- need to do a partial string match
if (string.find(event, eventname) and string.find(eventtime, starttime)) then
-- this event matches the input parameters so we return the description
return eventdescription
return "No Events"
-- Main Program
-- get the information on the next event
local gcNext = luup.variable_get(GCAL_SID, "gc_NextEvent", lul_device) or "No Event"
local gcNextTime = luup.variable_get(GCAL_SID, "gc_NextEventTime", lul_device) or "No EventTime"
--get the description for this event
local gcNextDescription = getEventDescription(lul_device, gcNext, gcNextTime)
local Msg = "Event " .. gcNext .. " at " .. gcNextTime .. " has description " .. gcNextDescription
luup.log(Msg)
Thanks so much @Stuart this is a great help.
If I could ask one more thing, as I canāt seem to work out how to do it myself ⦠???
Calling - ⦠gcNextTime ā¦
Returns - 23:00 Sep 07 to 00:01 Sep 08
How can i separate that gcNextTime variable so i can use/call ā23:00ā and āSeptā and ā07ā separately ?
Take a look at the line
you could create separate variables to capture the various bits and pass them back in the function call. Google āluup os.dateā and you will find details of the formatting.
or you could use something like string.find using the gcNextTime value
local _,_,time,month,day = string.find(gcNextTime, pattern)
you will need to figure out the pattern. Google āLuup string.findā and you will get plenty of examples.
Another comment: I HIGHLY recommend you get a copy of ZeroBrane as you can easily execute and debug elements of your Lua code without needing to have it execute on the vera. A slightly more advanced usage also allows you to run your code on the vera. Personally - I mostly use it to syntax check and to try out things (like getting the patter on string.find correct).
Ā© 2026 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
