I have several short term properties where I have a Vera Lite working with a Schlage touchpad locks.
It is important to me to be able to remotely change the code when I have new guest arrives.
My other four Schlage/Vera combos work perfectly, I know how to use the lock like the back of my hand.
I just installed a new Schlage lock with a Vera lite comby in a new property.
- It installed and paired easily.
- I am able to remotely delete codes, lock and unlock the door.
- I am able to program the lock using the keypad at the door, including adding codes.
What it wont do is allow me to program the codes remotely from Vera.
I am able to enter the codes on Vera, it says “Code Entered Successfully”
That code will not work on the door.
It temporally adds the code I entered on Vera on my list of codes, and then removes it a few minutes later.
What is going on?
- Vera Lite 1.7.1040
- SCHLAGE BE469ZP CAM 619 Connect Smart Deadbolt with alarm with Camelot Trim in Satin Nickel, Z-Wave Plus enabled
