Evening all. I just install a schlage deadbolt lock, Vera web interface is showing the device unlocked when it’s locked and locked when it’s unlocked. I tried it several times on my iphone and also PC. Anyone experience this issue?
I installed a Schlage lock incorrectly and the lock/unlock were swapped. Not sure if this is whats going on in yours. Had to reposition the inside knob by 90 degrees if I remember correctly.
Thanks I’ll give it a try/check.
