I have 3 Identical schlage locks configured. 2 of them work great, the third is unresponsive unless I remove it and bring it close to my Vera.
I have a GE Jasco switch within 2 feet of the lock which operates fine. I have replaced the batteries in the lock and tried removing and then re-including the lock twice without luck. It is almost as if the system is not communicating through the nodes, just directly to Vera. In order to configure the lock, add PINs, etc… I need to bring it close to the Vera.
Shouldn’t the Jasco act as a signal repeater? Are there settings for this?
Cheers!
PD
