I have a new Schlage lock. As is typical with these due to the myriad firmware they have, it doesn’t work reliably on my newer Hubitat but works just fine on my VeraSecure (go figured, my older Schlage works just fine on the Hubitat.)
Goal: create a routine in the Alexa app to simply announce that the lock has been locked/unlocked.
Issue: when choosing the When this happens condition this lock isn’t appearing via the Vera integration. (The other lock appears just fine from Hubitat, btw.) This lock appears normally in the Alexa app and can be controlled as an Action under Add Action perfectly well.
Hello @gwp1,
Please note that Alexa can’t control security devices on Vera. You can read more about it here.
I would recommend creating a virtual device that’s linked with the door lock’s status and that can be detected by Alexa. If you want to receive support on how to do this, feel free to send us an email at support@ezlo.com.
Kind regards!
Actually, I can control the lock via Alexa with the addition of Alexa-based security codes. But that’s not what I’m interested in doing. I just want the ability to have Alexa announce when the door is locked or unlocked. The same lock thru Hubitat has the same security imitations but allows me to create status announcements.
I used to be able to lock my door via Alexa app and it would state the door is locked. That stopped working many weeks ago. I had to add it to a routine to restore the ability for it to lock, but I no longer get the verbal cue that “the door is locked” I was told it was a skill issue by support.
