Is their a way when someone access the schalge keyless entry? I was thinking it would be great to have what code was enetered at what time so I can see who has come and gone last. I think the Schlage allows 16 unique codes. Is it possible to have events triggered when someone enteres like raise heat and sgut off alarm?
[quote=“83SanDimas, post:1, topic:168479”]First post here…
Is their a way when someone access the schalge keyless entry?[/quote]
Just hit the “notifications” tab in the lock setup box- you’ll see your options there.
[quote=“robinnes, post:2, topic:168479”][quote=“83SanDimas, post:1, topic:168479”]First post here…
Just hit the “notifications” tab in the lock setup box- you’ll see your options there.[/quote]
I think what he’s looking for is a constantly updated list of usage which isn’t provided by the notifications tab or anywhere else that I can find. You’d think this feature would be present since it has been for key pad locks for decades.
[quote=“S-F, post:3, topic:168479”][quote=“robinnes, post:2, topic:168479”][quote=“83SanDimas, post:1, topic:168479”]First post here…
I think what he’s looking for is a constantly updated list of usage which isn’t provided by the notifications tab or anywhere else that I can find. You’d think this feature would be present since it has been for key pad locks for decades.[/quote]
You mean some sort of login sheet that shows past entries?
Yeah, that would be nice- maybe someday.
If you’d like I can post some screen caps of one of my scenes that turns on our foyer light wen someone enters a pin after sunset so you get the basic idea of how a scene works…
I just installed my first Schlage deadbolt so I’d like to see your code, please!
Also, is there any way to put the device is a mode where you can run a ‘heal’ process to update the neighbor list? I’ve entered the 6 digit program code, yellow light blinks and then goes solid, but it doesn’t stay ‘on’ long enought to complete the heal process. My Vera 2 unit is pretty far from the installed lock so I want to make sure that it knows who the closest neighbors are to optimize communication.
I expected a lot of luup code in your response. I didn’t realize that so many new scene “events” were available for the Schlage device which will do most of the work in creating the scene.
