Has anyone been able to get the Ezlo to pair with one of these locks.
I am looking for a replacement for a Schlage FE599.
Hello @sdtoddl
Yes, the Schlage JFE109 is compatible with our eZLO controllers.
Does the Ezlo fully support all features? I was able to pair a JBE109 to a Vera Plus. From the IOS app and the web interface, I can lock and unlock the lock. Although, when I try to add codes, the coded show up in the app but the codes don’t work in the lock. I am wonder if this is just a compatibility issue with the Vera Plus or will this problem also occur on an Ezlo hub?
When I try to add codes, the codes show up in the app but the codes don’t work in the lock. I have tried this on a Vera Plus. Is there a difference between the Vera Plus and the Ezlo controller when it comes to the JFE109. The Vera Plus is able to lock and unlock the Schlage. The only issues are the codes.
Hello @sdtoddl,
Unfortunately, the Schlage JFE109 is not integrated with our Vera controllers. This is because the device is newer than the controllers themselves, and development for Vera has been officially discontinued.
As a result, no further device integrations or firmware updates are being made for Vera systems.
If you’re considering alternatives, we’d be happy to help you explore our newer Ezlo platform, which supports ongoing development and broader device compatibility.
