The Schlage BE469NX deadbolt has a built-in alarm that can be set to go off 1) anytime the deadbolt is opened, 2) if the deadbolt is jostled slightly, or 3) if the deadbolt is forced opened. The default setting is 3.
Does anyone know if this Schlage built-in deadbolt alarm can be tripped on (then later turned off) from the Vera controller when a separate sensor sensor device – such as a window/door sensor or motion sensor – is armed and tripped?
