My new Schlage lock paired with my Veraedge fine. Of course I had to put the Veraedge a couple feet away from the lock to accomplish it but it worked. I see it with my other devices and can lock and unlock it from my Vera screen. However even though the vera screen for the lock has an add pin code and lets me add a name and a new pin code and tells me it was successful it doesn’t work. When I try the pin code nothing happens. I have added 3 using the method described in the user guide and that worked. It would be nice though to see names and pin codes. The new pin codes do show on the screen but with no details. Just 1,2 and 3. Is this normal? Thanks
Yes that’s normal. I can’t remember what I did to get Vera to add pin codes with the names.
Did you change the max pin size in Vera to match the pin size on the lock?
It’s on the Advanced > Variables tab about half way down.
As I’m sure you have realized the names are not editable in Vera if you add them on the lock itself.
After thinking about it more I think I read that it take over an hour for Vera to setup the secure connection or whatever it’s called. Have you tried to set up a pin again?
