I am trying to have a “AWAY” mode Scene, by creating a custom scene that is triggered when in enter a PIN on the lock. I have configured schlage to ask for PIN on lock too. So to differentiate schlage getting locked versus unlocked via the pin, I have put in a LUA code to check lock status and return true or false. But that does not seem to work. When I put the LUA code it does not proceed.
local status = luup.variable_get("urn:schemas-micasaverde-com:device:DoorLock:1","Status",13)
return (status == "1")
I need this so I can have a “COMEHOME” scene which will conditionally run only when I unlock via the PIN.
I am trying to log this data, but I am not able to figure out how to access the log. I am using the veraedge via the home.getvera.com url. I just cannot access it locally on my LAN. any help with access veraedge on local network?
Substitute your local Vera IP address, of course. Also, Vera is very case sensitive. Be sure that your file name specified above exactly matches the log file name that your used in the Vera function. (The same thing can be said about Vera statements, as noted above.)
Also verify that you have enabled local access to your Vera through the Vera settings.
The easiest way to do this is to pre-assign an IP address to Vera, using your Router interface. Essentially you get your MAC address of your Vera, then specify on your router that Vera’s MAC address is always to a specific IP address.
You will need to get your router manual out. If you need it, see if a friend (or an available 10 year old) with networking experience can help.
I do not have UI7 or an Edge, so can’t help you there.
:). I am a software engineer. So did all these basic things. It still does not seem to work with UI7 and Vera Edge. So there is something more than basic networking to it.
