Hello,
I have created 2 PIN on the scalage 469. with the goal of using 1 pin to trigger the “away” scene that I create and another to trigger the “backhome” scene that I create. the scenes are triggered via “PIN Code #1 is entered on Schlage Deadbolt” type triggers.
I have create 2 PINs, but 1 PIN always triggers scene correctly and the other PIN nevers triggers the scene it is associated with. Is this a defect in scalage OR Vera?
Did you ever get this working?
I’m having an issue where all my PIN codes are considered to be index #3 when it comes to matching scene rules.
Can anyone with this schlage lock confirm they can fire off scenes using different pin indexes?
I’ll try this later tonight. Just installed it yesterday. Are you guys able to get notifications for bad pin entered?
Mine works. The scenes fire off accordingly - per pin entered. I tried it with 3 different pins/index. I just can’t get bad pin notification to work.
