How do I run scenes within a scene?
I set up an “All Off” scene that I want to trigger with other scenes. How do I do this?
Thanks.
Thanks.
Put this in the LUUP tab of the master scene to have it run scene number 5
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "5"}, 0)
[quote=“Z-Waver, post:2, topic:195556”]Put this in the LUUP tab of the master scene to have it run scene number 5
Wiki - Luup Scenes Events[/quote]
Kick ass. This should be easier, but there it is.
…or you can simply define a global function in Startup Lua which can be called by any scene. No need to make the code you want to share a scene itself.
It’s Monday, I’m struggling to understand your meaning here. Are you referring to an aliasing function like:
function ExecScene (SceneNum)
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = "SceneNum"}, 0)
Then use ExecScene(5) wherever you need to? Or are you meaning something else?
Almost. You just need to leave off the quotes around the SceneNum parameter…
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1", "RunScene", {SceneNum = SceneNum}, 0)
[hr]
Edit: …although it wouldn’t have to call a scene, it could just contain the code that was in the scene.
That’s pretty brilliant… wish I had thought about it sooner. Already created all my scenes.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
