The status is being reported by Vera. Scenes are considered active when the devices of that scene are correctly set e.g. under the Advanced settings of the scene you’ll see “Scene is Active - when all devices in the scene are properly set”. For example, say I have a scene to turn on my living room lights at sunset. The scene is configured to have the living room lights on. If I turn on the lights say during the day, Vera will mark the scene active as the living lights are on and that matches the settings of the scene minus the time. Vera will only check the device settings to mark the scene active or not and will ignore times, triggers, etc.
- Garrett
