REACTOR should be pretty easy to work with.
On the top you have “Conditions” and also “Activities”
Start populating your “Conditions” box/group with the items you need, within a box/group it is “AND” and multiple such boxes/groups are evaluated “OR” style.
So simply select the 3 “relays”.
A switch,relay is under the “Service/Variable” , so select this, then the next drop-down box you can scroll and find those 3 “relays” that need to be “ON” in order to make this “True”
The “status” of such relay is probably called “Target” and value you put “1” (=on) or “0” (=off)
Eg. in my case I have a switch I check like this.
Service/Variable / #3452 My Lamp / Target / Not Equals / 1
So reactor will evaluate this as TRUE IF my lamp is currently NOT active.
Then go to “Activities” en simple select the “Scene” you can to run when the status become TRUE and another scene if FALSE (so the “tripping” and “un-tripping”)
You cannot select a “device” , but you must make 2 new scenes, “Manual” trigger. So no schedule, no LUA-code, nothing fancy.
BOILER_ON , a “Manual Triggered” scene and simply select the relay/device that drives your boiler and enable it
BOILER_OFF , a “Manual Triggered” scene and simply select the relay/device that drives your boiler and disable it
Then in REACTOR you associate them : TRIP_SCENE = BOILER_OFF , UNTRIP_SCENE = BOILER_ON
So basically if ANY of the 3 relays are NOT “OFF” then the BOILER_ON is “triggered”
My understanding, like PLEG, Reactor will pick up where it left off.[/quote]
Those it mean no more : Error in lua for scenes and events ?[/quote]
I would guess. I have not seen that kinda of error in a number of years. I have been using PLEG for a couple of years and even when I have a LUUP restart in the middle of logic, it just continues.
As an example, at 530 am, my bedroom ceiling fan turns off and 2 nightstands ramp up to full brightness in about 60 seconds. There have been times when the lights stop ramping up, for like a minute, and then continue ramping. My Pushover notifications indicate there was a LUUP restart at 5:30, which interrupted the ramp up, but PLEG continued it once Vera was back up and running.
