I use a spread sheet to activate scenes based on available power from a wind turbine
Using the following links example
http://192.168.1.71:3488/data_request?id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=1
http://192.168.1.71:3488/data_request?id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=2
http://192.168.1.71:3488/data_request?id=lu_action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=3
I presently only use the scenes immediately without any other delays in the scenes
But I now want to use delays in the scenes that get cancelled out if a lower scene number is activated but the scene that was just activated delays to still work
Example scene 2 activates and cancels delays in scenes 3 to 10 or any scene greater than 2 if that easier I presume that some Luup code placed in each scene would do the trick or is it possible to amend the links above to do the job
Some help here would be gratefully accepted
