I have 2 devices (1 evolve dimmer and another AEON microdimmer )
I want turn on the aeon when the evolve is turned on thru a scene.
then I create the scene and choose the aeon device and put in the 100% then I put in trigger a device is turned on, turned on, and choose the evolve dimmer.
save
then I turn on the evolve dimmer but the aeon do not turns on…
what can be happen ?
exist another way to do this ? or only thru a scene ?
I think my trigger is correct and the logic of the scene, maybe a problem with this 2 devices ??
alone that works fine…
I’m doing something like this to switch on the shed lights (on a GE outdoor plug) when I switch on my Lania lights (On a GE switch)
I created 2 scenes, one to switch on the outdoor plug and one to switch it off.
The trigger is when the state of the GE switch is turned off or on
1 device is turned on. It runs the Shed light on scene immediately
2 device is turned off. It runs the Shed light off scene immediately
You might have more success using PLEG so you could trigger your action when LoadLevelStatus > 0. I have noticed that some dimmers do not update Status when turned on and off.
the curious is when turn manually by vera dashboard do not trigger the scene.
As I said, [b]Status[/b] is not always updated. In some cases control is entirely by setting [b]LoadLevelTarget[/b] which then drives [b]LoadLevelStatus[/b].
