Hi all,
I have an issue controlling my shutters. I don’t know if it is related to the scene or to the shutter modules, but this is what happens:
- scene to close the 4 shutters around sunset in my living room (each shutter starts to close with interval of 5 seconds) seems to work fine.
- scene to open the 4 shutters around sunrise in my living room (each shutter starts to open with interval of 5 seconds) is not reliable: timers are not accurate (sometimes shutter only starts to open minutes after it should, sometimes a shutter stays closed etc). Already deleted the scene and started from scratch and removed the timers, but this does not make things more stable. Status of the shutters position is not always accurate either (I have a scene lowering some shutters 65% when sun is shining, sometimes status shows it is still open while in reality it did shut).
Anyone who had similar problems or an idea what could be going on?
Regards,
Kristof.
VeraEdge UI7, 7 FGRM-222 shutter control, 2 FGD-212 dimmer, 4 FGS-212 relay, ZXT-120 AC control, FGMS-101 3 in 1 sensor, 3 FGK-101 door sensors, Aegon HEM 2nd Edition energy monitor, FGSD-002 Smoke sensor, 2 Foscam IP camera, Imperihome, link to X10 & Oregon & Chacon using RFXcomm
