I have 8 Philips Hue bulbs located around the outside of my property - in a Welcome Group.
I’d like them to come on early in the morning, then go off after sunrise. I’d like them to come on just before sunset and go off at around midnight. All very simple to do - either via Vera or via the Hue app. (if you forget the sunrise and sunset requirement).
What I’ve found is that - because the bulbs are quite spread out and I suppose the connection isn’t rock solid 100% of the time - that the Vera control of these bulbs via Luup seems a bit hit-and-miss. Whereas, if I press the button to turn them all on or all off on my Hue Tap switch, you can guarantee they’ll do as told. I control all of my Hue Bulbs in Vera Scenes via a line of Luup:
luup.call_action ("urn:upnp-org:serviceId:Dimming1","SetLoadLevelTarget",{newLoadlevelTarget="0"},deviceNo)
What I’m really wanting to know is this… is there a difference in operation between creating a Vera Scene (trigger, devices, action) vs. me selecting a trigger and then writing some Luup, like above, to turn the bulbs on and off?
Obviously the Luup method, I’m assuming anyway, is fire-and-forget - I send the command and I hope for the best. I do put it in a loop for each bulb, but it’s still not perfect - I can’t depend on it. But is the Scene method one where it sends the command to each Hue bulb and then checks that the command has been received and actioned by checking the bulb’s state?
Or not?
This is actually my - kind of brute force - code to turn all the Welcome Hue Bulbs off:
for i=5,1,-1 do
for deviceNo, d in pairs (luup.devices) do
if (d.id ~= "") then
if (d.category_num == 2) then
if (d.room_num == 14) then
luup.log ("SCENE Welcome Lights Off After Sunrise: Setting " .. d.description .. " to no brightness.")
luup.sleep (100)
It works, mostly… sometimes the odd bulb will be left behind. Any answers to my question, or suggestions for my code, will be very much appreciated.
