I have Vera Plus, wondering if I can do the following with just VERA SCENES (not PLEG as I always have trouble with that, just can’t get it, lol)
IF Between Sunset and Sunrise
AND the Front Door is UNLOCKED
THEN turn on the Porchlight
Thoughts?
Thoughts?
Try Rigpapa’s Reactor plugin, easy to use and offers exactly what you are looking for.
Also possible with just a couple of lines of Lua attached to a scene to turn on the light. Your time constraint is already described by the function luup.is _night().
http://wiki.micasaverde.com/index.php/Luup_Lua_extensions#function:_is_night
Day and night plugin would do it I think. Reactor would be my route but I assume akbooer’s solution works ![]()
C
Thanks All, i’ll give Reactor a try, i’m hearing great things.
