Scene not found
Home buddy widget shortcut to scene that unlocks door says "scene not found " when pressed. This is only for the Yale lock. Made new scenes that work controlling other devices. Also deleted and remade this unlock scene , doesn’t work. I also Googled but found nothing. Am I the only one with this problem?
Did you delete your scene and create a new scene with the same name ?
It may have cached the old scene # and is trying to run it.
I had never deleted a scene, but that’s why I tried creating a new scene with different name to localize problem to the lock. Scene works when pressing unlock in main app, just not in widget. Doesn’t run in Tasker either.
If at first you don’t succeed, uninstall reinstall. Works now.
