i have a scene with multiple event trigger (all my sensor) and who run a luup code
in the lump code how to get the event name who launch the scene to use it in lump action ?
thanks for your help
Huh, good question. If there is one, it’s not documented anywhere.
Try this as a workaround…
For each event, go into its “Luup Event” code and set a variable:
triggeredby = "Door1Opened"
return true
Then in the main Luup tab, see if you can act on this variable:
if (triggeredby == "Door1Opened") then
I don’t know if the variables you set in Luup Event code tunnel through to the main Luup code. Let us know if it works.
Hi
good response , it’s work
just one warning defined variable in lump event code is a global variable, if you use multiple event of this kind, think you use different variable name
thanks futzle
