I have a Vera Plus. And I have alot of scenes where I execute luup code for some custom behavior.
I noticed when I make certain calls, I feel like Vera is waiting for call for finish (blocking call) before continuing with the rest of luup script.
For example, I have the following function defined in my luup startup:
function mobile_app_alert(msg)
luup.call_action(“urn:intvelt-com:serviceId:HWPush1”, “SendMessage”, {Msg = msg}, 43)
In my scene luup script, I may call the above mobile_app_alert function to send a Homewave push alert based on some if-then-else conditions. I get the sense that Vera is executing this function and waiting for it to complete before proceeding with rest of luup script. I think this is called a “blocking call”?!?! Is there anyway to tell Vera to execute a function in a non-blocking manner?
Vera Alerts Mobile (Currently Android, but IOS soon)
I use an iPhone. Is iOS supported now?
@intvelt My family uses Homewave to control Vera. I trigger a Homewave push notification using the luup.call_action listed in original post. I did some tests. Do you know why it takes ~10 sec for the push notification to occur? Just wondering if it’s a limitation with how iOS supports notifications or is there anything I can do to improve this. Thanks.
You can use Vera Alerts plugin forwarding … to forward to Homewave
Then when you send to Vera Alerts, it will return right away, and in the background it will send to Homewave.
I have not done the Vera Alerts Mobile for IOS. But there a few service options for IOS devices.
