Scene for Yale door.
Hi guys, I am writing to you from Kyrgyzstan, so I apologize for my English.
I have a problem, I need a scene.
That will work when I open the door and then the light will turn on in the room.
I have a door lock model of Yale, and several light devices.
And I would like when you enter the pin code or using a door key, turned on the light. :slight_smile: :slight_smile: :slight_smile:
Have a look here to get you started:
http://forum.micasaverde.com/index.php/topic,2355.msg9382.html#msg9382
  • Garrett
Thank you Garrett but it’s not that there’s any ideas you ;D
Please answers, i need do this work, may be anybody have ready scene, thanks)))
Hi Nurdin,
Create a scene to turn on the lights and add 2 triggers selecting the door lock device: the A PIN code is entered event and the A door is locked or unlocked event.
Thank you for your reply. More specifically, I need to create a scene on a light or a castle?
Can you rephrase the question? The translator didn’t do a good job. I assume there was no castle involved in your question. :slight_smile:
I have a door lock firm Yale and devices Sofit Light. When I create a scene for the door lock and light, everything works (the door opens and light turn on).
but my door lock has the function of the input pin code and open with the key and I have the problem, how to do it. I need when I enter the pin code or when I use door key , the door should open and the light should turn on.
I did what you advised but it did not work, but thanks anyway. mcvflorin
When you created the Trigger, where it asked for the PIN code index number, did you put the PIN code or the PIN code index (for example 1 for the first PIN code in the list, 2 for the second one, etc.)? You must put the index, otherwise it won’t work.
Thanks, I’ll do what you said. The result I will write tomorrow.
On your advice, I introduced the index (thanks for this information), but the light does not turn on.
maybe we should prescribe Luup-code.
How do you think? mcvflorin
Luup code isn’t required for such a scene. I attached some screenshots with how the scene is supposed to look if created correctly. Does you scene look similar?
Dear mcvflorin, I stuck my skrishotys, I did everything you advised. I did the same steps as in the pictures.
But light did not turned on. What do you think about this? ;D
Nurdin, you should contact Tech Support so they can find why the scene is not triggered by those events.
OK
Just one question. Maybe the scene is not working because I’ve connected two Vera3? :slight_smile:
Is the scene on the same Vera as the door lock? Try making the scene on the Vera with the door lock first, and if it’s not working, make it on the other Vera.
