That is just the tip of the iceberg.
The setup:
[tt]Vera Edge |–20ft (6m)–> Linear Siren |–14ft (4m) → Linear Wall Mount Outlet |-- 20ft (6m) → Linear Wall Mount Switch |-- 20ft (6m) → Ecolink Door Sensor[/tt]
[tt] |–14ft (4m) → Ecolinc Motion Sensor[/tt]
Vera Edge 1.7.1707
Linux MiOS_45015360 3.10.34
Construction type: concrete & brick
Description:
Everything seems to work fine up to the Linear Wall Mount Outlet (WO15Z-1) and the Ecolink Motion Detector (PIRZWAVE2-ECO).
The next device is a Linear Wall Mount Switch (WS15Z-1). This is where the problem starts.
Most of the time, Vera Edge controller will report it as “Can’t Detect Device”.
The next device is a (battery powered) Ecolink Door Sensor (DWZWAVE2-ECO). Vera sometimes also reports it as “Can’t Detect Device”, and sometimes it shows and works ok, even if the wall mount switch is not detected. I guess it is routing through the wall mount outlet instead.
When the door sensor is detected (or at least, ther is no “Can’t Detect Device” message), it sometimes reports it is open (The distance between magnet and sensor is very small… way inside the max range specified in the manual).
To complete the description, I have a very simple scene which turns on the wall mount switch whenever a motion is detected in the Ecolint Motion Sensor.
The scene runs fine even when the Vera controller says it “Can’t Detect Device”… so how on earth can it send the on command?
The latest firmware (1.7.1707) does not include repair/heal option, since it is supposed to be taken care automatically.
I know that battery powered devices don’t relay signals, but as you can see I have hard-wired devices every few ft
I also know there is a maximum of 5 hops to reach the controller.
So why on bloody earth this simple setup just don’t work. I have been fiddling with it for 2 weeks now, and it doesn’t seem to stabilize.
Vera support has not been of any help.
So basically, the question is what do you recommend to troubleshoot the bloody thing.
I’m a daily Linux user and software developer, and am not intimidated by the command line, so if you have some low level tips, they are more than welcome.
I haven’t found a reliable way to get a network topology matrix, other than taking note of the “altid” and “neighbors” properties on the “Advanced” section of each device.
In my exasperation, I have also tried to “help” establish a sane topology by editing the “neighbors” field… which I am not sure what effect it has if any.
Any help will be very much welcome.
