I’ve noticed that my scenes that execute for Armed Detailed State values ‘Armed’ and ‘Disarmed’ no longer are executing, however the state ‘Stay (partial)’ works. They all worked until a month ago. I’m not sure what I may have done at that time.
I recently upgraded to a VeraPlus and that went well, but did not change this behavior.
Any guidance is appreciated. I believe the state changes in the variables, but I don’t see a RunScene executed in LuaUPnp.log
The scene trigger for armed detail state relies on a string comparison, between the DetailedArmMode state variable and the event strings in the D_CaddxNX584Partition2.json file. It’s hard to imagine that they stopped matching suddenly but I can’t think of a mechanism that would have caused these strings to stop matching.
That, or something’s stopped Vera from properly parsing the D_CaddxNX584Partition2.json file and so it no longer triggers events based on the DetailedArmMode variable.
I have a perverse feeling that if you deleted the scene and created it anew, it’ll start working again, It’s happened before.
Scenes, Notifications, PLEG, … link triggers to an ID in the related D_XXX.json file. The scenes also contain arguments to match to state variables for that ID, and these arguments are of course Trigger/ID specific.
In the upgrade from UI5 to UI7 MCV has changed (rearranged the Trigger definitions) what the IDs mean … so now your Scenes, Notifications, and PLEG may be linked to different trigger definition and/or a changed argument.
If you have problems … just delete and re-create the trigger.
Note: I have seen these in “Security” related devices … which I believe is being done as MCV plans to get into the Home Security monitoring business.
