Rather than add to the last topic from a long while back…
Does anyone else (still) get this error? Apparently at random, depending on the last LUA saved? I’m running UI7 latest public on a VeraPlus.
What’s interesting is that I have ZeroBrane and the first statement that should be executed in the scene function is the mobdebug require. However since the debug session doesn’t get started I’m guessing that the issue is somewhere in the Luup engine.
As I have multiple ZRC-90’s the LUA code is easier than (apologies) kludging virtual switches for PLEG (unless anyone has a more elegant method they have working for UI7).
one line of code in the scene and it does not work. i get failed attempt to call nil value
to turn on a light device 141
luup.call_action(‘urn:upnp-org:serviceId:SwitchPower1’,‘SetTarget’,{ newTargetValue=‘1’ },141)
i try it with double quote
i had it running and it stopped working
Is there a chance that’s not the line where the code is failing?
If you can run that line under “Apps” > “Develop Apps” > Test Luup code (Lua) it might be an indication that the issue is somewhere else.
If the problem persists, please send an email to support at support@ezlo.com.
