I have two scenes I setup to control my front porch light. One turns on the light at 20 minutes after sunset, and the other turns the light off at 1AM. Those scenes were working fine the first couple days, but now I’ve noticed in the last few days that either one or the other doesn’t seem to be working. Today it missed turning the light on. I ran the scene manually about an hour later and the light turned on fine. The switch is a X10 on/off switch, probably an old Leviton model. It’s being controlled by the insteon PLM. Below are some filtered log entries for both when it didn’t work and when I ran it manually.
Automation run:
26 01/27/14 17:41:34.699 INJob_GenericSendFrame::Run job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 sending cmd id 0x63 to node m_bSendToAllNodes 0 m_listIns
teonFrame 2 <0x2ca8b680>
01 01/27/14 17:41:54.803 [[31;1mINJob_GenericSendFrame::Run failed to run job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 command 0x63 abort 0 lower priority 0 ret
ries 3 node 6274424[[0m <0x2ca8b680>
26 01/27/14 17:41:54.804 INJob_GenericSendFrame::FindNextFrameToSend job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 reached end <0x2ca8b680>
26 01/27/14 17:41:54.804 INJob_GenericSendFrame::FindNextFrameToSend job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 aborting too many retries for frame comman
d 0x63 (4/3) <0x2ca8b680>
26 01/27/14 17:41:54.805 INJob_GenericSendFrame::FindNextFrameToSend job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 aborting too many retries for frame comman
26 01/27/14 17:41:54.805 INJob_GenericSendFrame::FindNextFrameToSend job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 reached end <0x2ca8b680>
01 01/27/14 17:41:54.806 [[31;1mINJob_GenericSendFrame::Run failed to run job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 command 0x63 node [[0m <0x2ca8b680>
10 01/27/14 17:41:54.807 Job::m_sNotes_set job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:1 dataversion 819521053 changing from -to- No response from node ;No resp
onse from node ; <0x2ca8b680>
10 01/27/14 17:41:54.808 Job::m_eJobStatus job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:2 dataversion 819521054 <0xb21150> m_eJobStatus Failed after 161.67845
9000 seconds callback:0 <0x2ca8b680>
01 01/27/14 17:41:54.810 [[31;1mINJob_GenericSendFrame::Run job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:2 done, failed 2[[0m <0x2ca8b680>
10 01/27/14 17:41:54.832 JobHandler::Run finished single job job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:0 <0xb21150> <0x2ca8b680>
02 01/27/14 17:41:54.833 [[33;1mJobHandler::PurgeCompletedJobs purge job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:2 x10 level #36 status 2[[0m <0x2ca8b680>
10 01/27/14 17:41:54.834 JobHandler::PurgeCompletedJobs purge job#112 :x10 level #36 dev:36 (0xb21150) P:50 S:2 x10 level #36 status 2 autodelete 1 <0x2ca8b680>
Manual run:
10 01/27/14 18:47:11.269 JobHandler::Run ready to run job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:0 x10 level #36 status 0 <0xdb4168> priority 50 tNextRunAttempt 0
<0x2c6f7680>
10 01/27/14 18:47:11.270 Job::m_eJobStatus job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 dataversion 877139115 <0xdb4168> m_eJobStatus Running after 0.4560000
seconds callback:0 <0x2c6f7680>
26 01/27/14 18:47:11.270 INJob_GenericSendFrame::Run job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 sending cmd id 0x63 to node m_bSendToAllNodes 0 m_listInste
onFrame 2 <0x2c6f7680>
26 01/27/14 18:47:11.406 INJob_GenericSendFrame::Run ran job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 command 0x63 node <0x2c6f7680>
26 01/27/14 18:47:11.407 INJob_GenericSendFrame::FindNextFrameToSend job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 found frame command 0x63 <0x2c6f7680>
26 01/27/14 18:47:11.407 INJob_GenericSendFrame::Run job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 found another frame <0x2c6f7680>
10 01/27/14 18:47:11.408 Job::m_eJobStatus job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:0 dataversion 877139116 <0xdb4168> m_eJobStatus Queued after 0.142495000
10 01/27/14 18:47:11.408 JobHandler::Run finished single job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:0 <0xdb4168> <0x2c6f7680>
10 01/27/14 18:47:11.409 JobHandler::Run ready to run job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:0 x10 level #36 status 0 <0xdb4168> priority 50 tNextRunAttempt 0
<0x2c6f7680>
10 01/27/14 18:47:11.410 Job::m_eJobStatus job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 dataversion 877139117 <0xdb4168> m_eJobStatus Running after 0.14513400
0 seconds callback:0 <0x2c6f7680>
26 01/27/14 18:47:11.411 INJob_GenericSendFrame::Run job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 sending cmd id 0x63 to node m_bSendToAllNodes 0 m_listInste
26 01/27/14 18:47:16.522 INJob_GenericSendFrame::Run ran job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 command 0x63 node <0x2c6f7680>
26 01/27/14 18:47:16.523 INJob_GenericSendFrame::FindNextFrameToSend job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 reached end <0x2c6f7680>
26 01/27/14 18:47:16.524 INJob_GenericSendFrame::Run job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:1 done m_bSendToAllNodes 0 bSucceed 1 <0x2c6f7680>
10 01/27/14 18:47:16.537 Job::m_eJobStatus job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:4 dataversion 877139130 <0xdb4168> m_eJobStatus Successful after 5.27207
2000 seconds callback:0 <0x2c6f7680>
10 01/27/14 18:47:16.550 JobHandler::Run finished single job job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:0 <0xdb4168> <0x2c6f7680>
10 01/27/14 18:47:16.551 JobHandler::PurgeCompletedJobs purge job#9 :x10 level #36 dev:36 (0xdb4168) P:50 S:4 x10 level #36 status 4 autodelete 1 <0x2c6f7680>
Anyone have any ideas?
