I’ve been getting some unexplained behavior on one Z-wave dimming module. I have a scene to turn the map on to a certain level in the evening using a timer. It comes on and goes off just fine. However, the lamp also comes on in the early afternoon (always the same time) which leads me to believe it is a scene/time command. However, in the dashboard, I don’t have any timers for that lamp defined other than the one that works as expected.
I checked the log file on Vera2 by logging into the shell. I found at the time that the lamp comes on a few commands showing a Scene #5 running and evaluating and a Scene #21 running and evaluating for the lamp status. Scene #5 is the correct working scene and it evaluates to false so it doesn’t turn the lamp on. However scene #21 evaluates to true and sends the Z-wave commands to turn the lamp on.
Problem is that I can not find Scene #21 in the dashbaord (UI4) anywhere. I’ve checked all my scenes to no avail.
Is it possible that an old scene that I had from some time ago was deleted from the dashboard, but never deleted completely from Vera? Is there a way to address this? Manual edits of config files ? Any suggestions?
