Just a quick thought — could you please double-check the quotation marks in your code? Sometimes when code is pasted into the forum, straight quotes (" or ') can get automatically replaced with curly quotes (“ ” or ‘ ’), which Lua doesn’t recognize and will cause a call a nil value error like the one you’re seeing.
Here’s what a corrected line should look like:
os.execute(“echo date +'%Y-%m-%d %H:%M:%S' motion >> /tmp/motion/garage.log”)
Make sure:
You’re using straight double and single quotes throughout.
The /tmp/motion/ directory actually exists on your system.
And finally, the end statement at the bottom — is that part of a function or loop block? If not, you may not need it there.
Thanks for responding. I know the Vera side of things isn’t likely to get much attention.
This hub is failing to run scene code that’s been in use for a couple of years. I’ve used that very line of code in other scenes and it’s never given problems. When the hub reloads I see this in the log:
01 07/14/25 9:56:15.640 JobHandler_LuaUPnP::Run cannot start lua with code:
function scene_61()
luup.call_action(“urn:micasaverde-com:serviceId:EnergyMetering1”, “ResetKWH”, {}, 2112)
And after that it shows the rest of the code from scenes in red. This is in a scene I’ve used for years.I know that if a scene has code that won’t compile the rest of the code in scenes won’t work.
ALSO: this is the first scene containing any Lua code.
We have sent you an email with a request to initiate a remote session in order to check your controller. Could you please confirm once you’ve received it?
Not sure where you sent the email. I didn’t get one. I have enabled remote access. Would I normally return the remote access code in that email? The email in my account preferences is correct.
Any progress here? The service led is off on my hub. Some days it’s on - others it’s off. When it’s on I know I can log in to access alerts. I assume that when it’s on the hub is connected to your server. Can you remote access the hub with the service led off?
That’s correct — we noticed yesterday that your controller is currently offline, but we hadn’t updated the case here yet. Could you please try connecting your controller via Ethernet to port 1 of the main modem and perform a power cycle?
We’ll be standing by to continue once it’s back online.
Tried what you suggested, connecting an ethernet cable directly to the output of my router - temporarily disabling ethernet to other devices on my network. The hub booted and the service led came on briefly - a few seconds, and then went off.
Could you please proceed with a network reset by quickly pressing the reset button three times?
Please avoid pressing it more than three times, as this will trigger a factory reset on your controller.
I have a second Vera Plus that I had running briefly over a year ago. I wasn’t really doing anything with it so I put it away as a spare. I’ve fired it up and connected it to the same gigabyte switch. It starts up ok and after several minutes all LED’s are on - including the service LED. Tomorrow I will try to put everything on that hub and see if scene code works as expected.
Thanks for the update!
To help make the troubleshooting process with your controller smoother and more efficient, feel free to reach out to us directly.
You can either:
Send us an email at: support@ezlo.com Or call us at: 1-866-966-2272
Our team will be happy to walk you through the next steps.
About the hub now stuck with the internet and service LED’s flashing; I believe it’s of no use in this state. Before I could at least control the devices that were attached to it. I could also connect using WinSPC. Will I have to to a full reset - using the reset button - to get back to some useful state? Or is there another way?
