Reading the forums some more it seems this can only be done with either some startup LUA code or PLEG. I am surprised Vera haven’t implemented this yet into the native UI7 GUI.
I found this thread here about the PLEG setup.
I wanted a double click S2 (down button) on the Lounge room Dimmer 2 to turn on / off the Kitchen ceiling lights.
Attached are some screen shots of my PLEG setup:
I really wanted only a double click on S2 (down button) to run the scene / action, but both S2 and S1 (up button) on a double click, report “14” in the LastSceneID in Device Properties.
So now double clicking down or up fires the action to toggle the Kitchen Ceiling lights.
This means on the Dimmer2 I’ve kinda lost the inbuilt double click up function to brighten the connected Lounge lights to 100%, it still works, but now it also toggles the Kitchen ceiling lights as well. There is a parameter #23. “Double click option - set the brightness level to MAX” setting this to 0 would disable it completely.
Anyway its now working and a double click up or down runs the toggle Kitchen ceiling lights action.
For completeness of information I am using a 3 position retractive switch (Roller Shutter type) On the Dimmer 2, I have parameter #20 set at 1 byte Dec = 2
The dimming up (Press up and hold) and dimming down (Press down and hold) is still working as before I added the scene activation functionality.
Pressing up once turns on the connected lights, pressing down once turns off the connected lights etc.
I also wrote about this Dimmer 2 installation on my blog here with photos, guess I need to update it now with this new information about scene activation.
If you actually want to run a scene on the PLEG Action I assume you would under the LUA tab just add a bit of LUA code to call a scene.
Might try this next with a triple click !
