This is one of the best plugins for Vera I have worked with!!
I have worked on over comming this issues for hours, here are the steps to reproduce:
Downloaded dkjson.lua.lzo from dkjson - dkjson
Uncompressed and copied dkjson.lua to /usr/lib/lua
Removed all Harmony Devices
Removed Harmony Plug-in
Removed all files that were created during Harmony Plug-in from /etc/cmh-ludl
Restored Vera backup from before Harmony Plug-in
Verified everything is running as expected on Vera 3 UI5
Verifed /usr/lib/lua/dkjson.lua still exists
Apps / Install Apps / Search by: Harmony
Installed “Harmony Hub Control” 2.19
Allowed Vera to re-load
F5 on IE
Open “Harmony Control” Device
Updated the following properties:
IP Address: {my harmoney hub ip}
Hub email: {my harmoney hub email}
Hub Password: {my harmoney hub ip}
Close “Harmony Control” Device
Click red SAVE button (UI5)
F5 on IE
Verify Link Status: Ok
Click on Activities Tab (Allow Activities to Load)
Activity ID button 1: PowerOff / Label button 1: Power Off
Click “Save Changes” button
F5 on IE
Test “Power Off” activity - Working!
Click on Devices Tab (Allow Devices to Load)
Select 5 of the possible 19 devices (Leaving "Create child device enbedded: No)
F5 on IE
F5 on IE
Open “HRM: Living Room Onkyo” Child Device
Click on Settings
Button 1 Command: Volume Up / Label: “Vol Up” / Press: 1 Sec
Button 2 Command: Volume Up / Label: “Vol Down” / Press: 1 Sec
Button 3 Command: Volume Up / Label: “Mute” / Press: 1 Sec
F5 on IE
Test “Vol Up” button - Working!
Test “Vol Down” button - Working!
Test “Mute” button - Working!
Create “New Scene”
Navigate to “HRM: Living Room Onkyo” Child Device
Click “Vol Up” button (Turns blue, it looks like it’s going to save it, Example1.jpg)
Click “Confirm changes” (UI5)
F5 on IE
Open “New Scene”
Notice that the “Mute” button is active (Example2.jpg)
Note: I have tried other child devices as well, same issue. I did have this working at one point with a single child device, this issue started after I added some additional child devices.
Please Help! Really Appreciate the help and this plugin!!
