Saving Local Data
Is anyone else getting this kind of error when saving any changes:
Saving local data …
Error saving data.
I’m on the current release and have three Vera units in production. I’m only getting this message on one unit.
Before doing anything, try turning on verbose logging, doing the save, submitting a trouble report, and posting the report ID. I want to see why this isn’t working with the release firmware. We did make a fix for saving. To test it, you can upgrade to this firmware: http://download.controlmyhouse.net/betafirmware/wl500gP-1.0.456.trx by choosing advanced, download and putting that in the ‘url’ field. This has the fix for saving scenes. You can see if this firmware fixes the issue for you. For me, I’ve tried at least 50 times to edit timers/events and save my changes and it works every time. If, with the 456 firmware, it still doesn’t work, please enable verbose logging (advanced, logging), and then reproduce the problem by trying to change a scene and save it. Afterwards, click advanced, tech support and submit a trouble report and post the report id in this thread. I’ll see what save data was received and try to track down the cause
I think I might have found the problem. I think that the issue occurs if you try to make changes while Vera is in the process of removing a dead node (or perhaps even otherwise occupied). I had been trying to kill a dead node and just now I went to set up a log to send you and noticed the dead node was removed. I tried to save changes and it worked like it should.
