Saving changed luup code in UI4 (1.1.1047)
I’m having a problem with the UI saving any changes I make to luup code in scenes. It works the first time after I’ve logged in from a new browser window. However, if I close the scene properties window and open a different one, edit the luup code, click “save luup”, exit the properties and hit “save” on the main page, when I return to the scene my old luup code is still present.
I’m assuming this is a known problem (I know, dangerous to do), but I was wondering if there was an ETA on an updated version for UI4 that would address this issue?
It seems like it’s a problem that isn’t contained to lua/luup code?!?
