Because the topic is closed I try it this way.
With your feedback I managed to solve the issue, but my problem was that there was no default value available after the upgrade. So the boxes for number of restarts and the minutes where empty. Because of that the issue didn’t resolve itself.
After entering 10 and 900 as mentioned in the other topic, the issue was solved.
No that’s not the reason. If the values are empty, the function that reads the variables provides defaults. You probably just spent enough time poking around and doing that the next restart was outside the window.
Okay, thanks for your reaction. Glad to hear it’s not a bug. But right after entering the values and restart Luup they all worked.
Thanks for all your help and great plugin!!!
